Author Topic: Series II Headlights  (Read 3368 times)
skyliner33wa
« on: March 30, 2002, 05:20:28 AM »
Hi all,
I really want to change from those series 1 headlights to Series II , :rolleyes: i was told and have read somewhere that you need to change the bonnet aswell, that a bit of a pain but can be done, i was wondering if i need to change my series 1 front bar aswell,
Also does anyone know how to actually get into the headlights, i have a few bugs in there, looks ugly as i got that plastic cleaner from just jap, it really does make a difference :) and its worth it anyway after cleaning, you can see little flies and sh*t in there i want to get them out
thanks
kris
MIC33R
« Reply #1 on: March 30, 2002, 12:21:51 PM »
What's the difference anyway? I reckon my Series 1 lights are pretty good looking, so I'm a little curious as to how good these S2 lights look.
PranK
« Reply #2 on: March 30, 2002, 01:08:46 PM »
MIC, mine is a series 2...
As for changing them, it'd be the bonnet, front bar/grille and maybe even the front quater panels.
Getting into the lights is not recommended as you will break the seal and they will leak and fog up.
MIC33R
« Reply #3 on: March 30, 2002, 03:39:52 PM »
Thanks Prank. It is a little hard to tell how they are different, but they don't look quite like mine. However, mine are tinted pretty heavily so probably look very different anyway. I've got yellow high beams and darkened low beams (possibly a slight blue/green tint).
PranK
« Reply #4 on: March 30, 2002, 03:46:22 PM »
The series 2 lights are slimmer like the R32 lights. The Series 1 lights are fatter and taller.
skyliner33wa
« Reply #5 on: March 30, 2002, 06:23:09 PM »
thanks guys pretty happy with the car i got now actually, changed my mind, will keep it series 1, don't really see the point unless my car was involved in a head on accident (like my silvia before my skyline reversed into by a garbo):rolleyes:
anyway thanks
kris
Node
« Reply #6 on: March 31, 2002, 02:44:30 AM »
what years are series II 33's
And are the cosmetic differences the only change?
My guess would be 97 as thats when silvia/240sx light styles where changed (i think)
lerker
« Reply #7 on: March 31, 2002, 03:50:43 AM »
Series II R33's are from around '95 onwards.
Yes the only difference is the cosmetics/body of a Series 2 compared with a Series 1... engine and interior are the same.
ex-static
« Reply #8 on: March 31, 2002, 06:07:52 AM »
from what i beleive the s2's were given a ceramic turbo also?
URMINE
« Reply #9 on: March 31, 2002, 06:45:35 AM »
lerker.. there were a bit of little mechanical changes in the series as well.. ecu, coil packs etc..
MIC33R
« Reply #10 on: March 31, 2002, 08:14:59 AM »
Exstatic,
Wasn't it the other way around? The S1s had the ceramic and the S2s had a plastic one?
PranK
« Reply #11 on: March 31, 2002, 11:01:35 AM »
Series 2 had the following changes:
ECU
Turbo (cermic wheels)
Interior Trim
Interior facia
Front and rear ends updated (including different bonnet impressions)
Coil Packs
S2 came standard with a rear mounted strut brace.
I think theres more... will find out.
clef
« Reply #12 on: March 31, 2002, 11:59:25 AM »
Series II has plastic, Series 1 has ceramic
The Series II are from mid 96 - mid 98.
URMINE
« Reply #13 on: March 31, 2002, 01:56:24 PM »
clef.. im pretty sure that the s2 turbo had a plastic compressor wheel where the s1 turbo had a steel one.. the s2 spools better due to less weight but doesnt boost as much..
and prank didnt we see a end of 95 series 2 last week? ndr's one?.. i thought series 2 came in at the end of 95?
clef
« Reply #14 on: March 31, 2002, 02:14:27 PM »
Well there are some '96 series 1s because they were still making them in 96 ..
The database on japimportcar.com backs me up on this too.
Series 1 ended in Jan '96, and series 2 started at the same time.
