Author Topic: R32 GTS-4 turbo vs R33 turbo  (Read 1340 times)
JiMiH
« on: April 06, 2002, 10:24:43 AM »
If I bought an R32 GTS-4 turbo and an R33 turbo (both in manual) and did 5 grand's worth of mods to both (identical mods), which would be quicker?
1/4 mile?
off the lights?
cheers guys:)
Nemesis
« Reply #1 on: April 06, 2002, 10:29:01 AM »
Wouldn't the 25t be quicker as it is quicker to start with???
Ant:skulls:
Unless of course, you mean in the wet...........
Grim GTS-t
« Reply #2 on: April 06, 2002, 10:42:25 AM »
The R33 would be quicker after 5 grand of mods. The RB25DET is more powerful to begin with and is more scalable (up) with modifications than the RB20DET. With good rubber and suspension the diff b/n the 4WD and 2WD isn't much compared to the larger power output of the R33.
Madniz
« Reply #3 on: April 06, 2002, 11:29:09 AM »
Well, around Manfield racetrack in the wet my standardish GTS4 was easily keeping up with standard(ish) R33 GTS25ts in the corners.  However, due to the massive understeer I was experiencing (I'm used to oversteer ... actually I love it :D ) I could not get inside or around them.
When we got to the straights, I had to just sit back and say byebye ... they were pulling out a couple of seconds on me. :(  Braking was the only other time I could bring back the gap a little, but I was braking hard and late. :D
Chris:dozey:
Duct Tape Death Match
V8eta
5g
« Reply #4 on: April 06, 2002, 01:00:27 PM »
With five grand of mods i think the cars would be fairly even, extra traction when you raise the hp of the 4wd makes a huge difference. Its different if you throw a pair of drags tyres on the back of a 25t. Four 5 grand you would hopefully do very low 13's, maybe even a high 12?
Ver 3 WRX STi type RA racer
JiMiH
« Reply #5 on: April 07, 2002, 06:57:18 AM »
Is it within the reaches of the average person to get a GTS4 into the high 12's?
Or is that just dreaming?
Doctor
« Reply #6 on: April 07, 2002, 07:30:31 AM »
I beleive if you get a t3/4 or a t4 turbo, decent intercooler, fuel pump upgrade and reprogrammed ecu I think high 12's are very possible.
Doc
GTRMAN
comparo
« Reply #7 on: April 28, 2002, 03:52:06 AM »
Or you could just get a R32 GT-R which does 12.97et standard!!!
darkness
  • Administrator
Re: comparo
« Reply #8 on: April 29, 2002, 07:13:54 AM »
Ah but then you could buy a gts-4 spend the extra money that you would need for a GTR to make the gts-4 go faster than the standard GTR.
AFK.
stainNZ
« Reply #9 on: April 29, 2002, 07:43:05 AM »
Chris:dozey:
Understeer?!
how were u getting that?, must be the slushbox eh ;)
