Author Topic: Which sub to buy  (Read 1985 times)
skyzerr33
Which sub to buy
« on: July 12, 2001, 11:51:03 AM »
I'm after a good quality sub.
12" which will run well off a low power while i save for another amp.
Can't decide over, JBL, Alpine, Pioneer, Kicker or Fusion.
What does everyone else have and or recommend?
L8r
Jay95R33
Which sub to buy
« Reply #1 on: July 12, 2001, 12:36:48 PM »
I've used two different sets on MTX subs in the last few years and can highly recomend them.
BUT - it comes down to the sort of music you listen to and also the space you have available.
J
skyzerr33
Which sub to buy
« Reply #2 on: July 12, 2001, 03:19:04 PM »
puttin in tyre well with false floor so rooms no problem.
music jsut about anything, rock, pop, dance, metal, movie soundtracks etc just not opera singing.
forsaken
Which sub to buy
« Reply #3 on: July 12, 2001, 06:57:15 PM »
I personally prefer the pioneer range for their subs. Their 12s are awsome, however I'm not sure how well they handle low power.
Fusion subs go low but they distort really badly and don't have very good sound quality.
Framed A3 Photographs for sale PM for information
Zapf
Which sub to buy
« Reply #4 on: July 12, 2001, 07:07:49 PM »
Yep I use the pioneer 12" as well. They have good quality and sounds nice... but not too loud... goes well with the system.
Zapf
cummas
subs
« Reply #5 on: July 13, 2001, 12:48:14 AM »
Kicker, Kicker, Kicker!
JasonO
Which sub to buy
« Reply #6 on: July 13, 2001, 08:40:59 AM »
"Infinity Perfect" work just fine for me, and have the ability to be mounted in many different enclosure configurations.
infintyR32
Which sub to buy
« Reply #7 on: July 13, 2001, 07:28:17 PM »
Yeah I am using the Infinity Perfects too.  I have two 10 inch subs in behind the rear seats rear firing into the boot.  Great subs cause the boxes for them are so small (great for the Skyline!!).  Polk Momo are the same too, great sounding as well.
Depends on what money you want to spend though!
R32crazy
Which sub to buy
« Reply #8 on: July 16, 2001, 07:35:30 PM »
This is not one of the brands listed, but I've used a Rockford-Fosgate®  (RF) 12" and its good, real good.
Mark :)
bizkit
Which sub to buy
« Reply #9 on: July 16, 2001, 08:35:42 PM »
well i have a 12" vega v flex and i love it, its not for people who need boot space as it requires a big box but with the right power it sounds nice and deep almost like a 15" but not quite.
danijel
GSR32
Which sub to buy
« Reply #10 on: July 17, 2001, 09:44:58 AM »
Some subs require decent power to drive them properly, now you mentioned that you haven't got huge power to drive it, so what to look for in a sub for your situation is one which has a high efficiency rating, this is normally in dB, the higher it is the more efficient it will be.
GSR32
Which sub to buy
« Reply #11 on: July 17, 2001, 10:10:05 AM »
Well, I have just done a little research on the net, and what ever sub you are thinking about, just check it's specs on the net. Some subs have a efficiency down around 88dB, bit too low, and most are in the 90's. Pioneer do a 12" one that is 106dB, 400W max and 100W nominal power.
Mr King
Which sub to buy
« Reply #12 on: July 17, 2001, 06:36:42 PM »
hey all
I'm afta a little more low bass and was wonderin if I should run two 10's or one 12
i've got my mid and higher frequencys pretty much sorted and was wonderin which to go 4????
2 10s or 1 12???
cheers        :king:
GSR32
Which sub to buy
« Reply #13 on: July 17, 2001, 06:59:15 PM »
Depends on the frequency response of the speaker, yet another case of checking out the specs. A 12" should provide lower bass than a 10", but you will get more bass with 2x 10" subs, movement of air theory ;)
skyzerr33
Which sub to buy
« Reply #14 on: July 17, 2001, 09:45:21 PM »
GSR32
Thanks mate.
Looked the other day, Pioneer is at the top of the list atm,just waiting for that all famous Tax check to come back hehe.
