Author Topic: Torque 4WD Dyno Day  (Read 3546 times)
RH9
Torque 4WD Dyno Day
« on: July 20, 2001, 09:14:52 PM »
Hey all, is it true that the 4th of August will be the inaugural four wheel drive dyno day?
Gosh those poor evos and Sti's finally get to see how they compare to some of Nissans finest :)
See you there...hope Robins got his S__t into gear!
GSR32
Torque 4WD Dyno Day
« Reply #1 on: July 20, 2001, 10:09:03 PM »
Don't hold your breath.:rolleyes:
BABY R
Torque 4WD Dyno Day
« Reply #2 on: July 30, 2001, 09:56:39 AM »
So, is this 4WD dyno day this saturday a go or not? I'm very keen to get my car on the dyno to see how it goes, anyone else keen to go?
EVIL-BUNNY
Torque 4WD Dyno Day
« Reply #3 on: July 30, 2001, 11:07:22 AM »
i would be keen to go if it was a rear wheel day :)
maybe hes got time to dyno tune his customers now that
hes stopped playing with his new dyno!
why tune one customer when you can tune lots on dyno day
:mad: :mad: :mad: :mad: :mad: :mad:
R U NUTZ
Torque 4WD Dyno Day
« Reply #4 on: July 30, 2001, 07:31:53 PM »
you guys with GTR pls turn up this sat.. it would b good to see some powerful gtr on da day. andy.. bring your "BEAST R " :D
i would be keen to run my car again in 2wd though since da link is fully mapped now.. :D
FRYLINE
2wd would be cool....
« Reply #5 on: July 30, 2001, 10:22:35 PM »
i would love to see what mine makes now it is all in order.
i know its not a horse power machine but i am keen to see...
fry
lurking still......
BABY R
Torque 4WD Dyno Day
« Reply #6 on: July 31, 2001, 12:07:36 AM »
Rudy, i love to see your car run on the dyno again. I missed it last time, i will not miss it this time round~~
See you guys saturday.  :o
power hungry
Torque 4WD Dyno Day
« Reply #7 on: July 31, 2001, 01:47:47 AM »
Yep Andy, I would love to see wot ur car gets. It did really well at the drags. I am not too sure if i could make it on Saturday, tho. So Robin has eventually got the 4wd dyno setup, huh?:)
FRYLINE
Torque 4WD Dyno Day
« Reply #8 on: July 31, 2001, 10:54:55 PM »
2wd     2wd
fry
lurking still......
power hungry
Torque 4WD Dyno Day
« Reply #9 on: July 31, 2001, 11:15:44 PM »
yep. u r dead right fry. Anyone wanna make a bet on a 4wd dyno:)?
GTcrazy
Torque 4WD Dyno Day
« Reply #10 on: August 01, 2001, 12:49:31 AM »
wow at last
RazorGTR
Torque 4WD Dyno Day
« Reply #11 on: August 01, 2001, 05:03:04 AM »
The way I look at it I am going to show with my GTST and see what we see. How many times in the past has Performance Car mag said it would be the 4WD dyno day and it is a non-event because of one reason or another. It is just one of those things.
I believe we will see simular numbers as we have always. Figure most of the Evo's mildly tuned to run @ 175kw - 190kw. Subbies will probably be 15-20 kw lower. The normal VR4's (pre 96 models ) should be in the 135kw -150kw range depending on how far in the mods they went.
Considering a Skyline is quite a bit heavier then the above mentioned and the GTS4's are running in the high 13's with tuning the same the power ratios should be the same or slightly lower but lets wait and see.
GraemeWi
    • http://www.overflow.250x.com
Torque 4WD Dyno Day
« Reply #12 on: August 01, 2001, 07:08:46 AM »
I was round at TP last Friday (27th) and the extra set of rollers were in place, they looked to be still putting the finishing touches to them. Maybe somebody could give TP a bell and see if they are going to be ready for this Saturday.
moondog
Torque 4WD Dyno Day
« Reply #13 on: August 01, 2001, 08:27:34 AM »
Surely a 2WD car could still do a dyno run; you just wouldn't use the second set of rollers??? Or am I missing something? :confused:
Wraith
    • http://www.wraith.co.nz
Torque 4WD Dyno Day
« Reply #14 on: August 01, 2001, 10:31:26 AM »
The second set of rollers were in place when the last dyno was run.
I believe that there was a problem with the hydrolics that move them backwards and forwards which caused it to be only a 2wd day last time.
What am I saying "only 2wd"... 2wd cars RULE!!!:dfinger:
Have Fun :D
Dave
MADNESS IS THE GIFT THAT HAS BEEN GIVEN TO ME
WRAITH.co.nz
