Author Topic: what should spark plugs look like?  (Read 463 times)
« on: June 10, 2001, 01:39:14 AM »
Mesmer
(4/26/01 5:36:47 pm)
Reply  what should spark plugs look like?
 I got around to looking at my spark plugs today and well they are denso Q20P-U plugs and they are black.
Are these plugs the same rating as what should be in there? all i could get off the jap site is that they are the ment to be the same fit as NGK BCP6E plugs?
and could i try to clean my plugs or just buy new ones?
thanx john
tazdev
(4/26/01 6:15:00 pm)
Reply  Re: what should spark plugs look like?
 I would probably buy new plugs as the Denso ones are probably the plugs it came out of the factory with.
Simon aka. Tazdev "TAZ like eggs."
blue t
(4/26/01 7:14:03 pm)
 White at the top and funny burny things at the end!
any doubt and you should probably change them!
Hee Hee
Mesmer
(4/27/01 1:07:37 am)
 I have a really bad problem with my car and it feels like its misfiring badly but only under 2000 rpm and stutters when i drive along some times. It seems to go away higher than that but i havn't gone over 4500 because i dont want to brake anything.
Could the fouled plugs be causing this?
The only other thing i can think of is a lead because i have checked almost everything else.
john
crooser
(4/27/01 2:37:41 am)
 what gapping is on your current plugs?
hows your tailpipe for black stuff?
Blaup
Melbourne Ozzy Admin
(4/27/01 3:31:54 am)
 Denso is toyota type brand, NKG or is that NGK's are what nissan usually use.
On that note i hear the denso iridium plugs are really good.
E
Mesmer
(4/27/01 11:24:24 am)
 Dont know the gapping because had nothing to mesure it at the time.
and if you mean black crap around the inside exuast there is a tone of it but no smoke.
John
crooser
(4/27/01 2:07:24 pm)
 could be that your getting way too much fuel (at lower revs)
and thats fouling your plugs...
what fuel mods do you have? aftermarket ecu?
take it to a shop with an air-fuel meter, they could tell you straight away.
does cleaning the plugs temporarily fix your prob?
cheers
crooser
tazdev
(4/27/01 2:55:34 pm)
 I sit corrected, thanks for that info Blaup
Mesmer
(4/27/01 4:00:28 pm)
 Yep i have a aftermarket ECU (autronic SMC) and coil packs and yes it runs very rich when idling or at low revs. Ok i think i narrowed it down to a lead (spark plugs still need changing and i will do that at the same time) because it worked fine when i took it out with out the cover on the top of the spark plugs and its went fine but then when i put the cover back down it started the problem really bad again (bending the leads to go to the plugs from the coils).
I also noticed a clicking sound when idling that is comming from the around the first cylinder that sounds like a eletrical arc or solinoid (spelling? :P ).
Any idea's?
Thanx
John
