Author Topic: Free Horsepower...  (Read 182302 times)
gtstCruiser
Free Horsepower...
« Reply #1320 on: December 21, 2004, 12:02:52 PM »
i pulled out my afm before i cleaned it.. and yea i cleaned it because when i bought my pod i noticed a nice blanket of 5cm worth of black grime and dust.. im thinkin its never been cleaned before since the orange sensor was then black before i sprayed it.. im just gonna buy another afm when i get enough money :(
madzilla
Free Horsepower...
« Reply #1321 on: December 22, 2004, 12:57:34 PM »
hello every1 dis site iz awesome and i have 1 question to repeat, how do i fool my waste gate into receiving low boost?  i have a bleed type controller
bluntsmoker
Free Horsepower...
« Reply #1322 on: December 22, 2004, 01:16:35 PM »
basically you need to use it to bleed off some of the pressure that the wastegate actuator receives.
I have a very simple set up on mine and it works perfectly.
I just put a T in the boost source for the wastgate actuator, with a hose running form the T to the bleed valve (which i found at Bay Engineering for $14)
Make sure you get a boost guage before you start tweaking. You shouldnt reallg go over 11 - 12psi on your standard turbo if you want it to last.
However whein i got my car it ran an unrestricted 15 -16psi which was fun  :jack:     Now back at a healthy 10psi
:mexican:
madzilla
Free Horsepower...
« Reply #1323 on: December 22, 2004, 01:23:51 PM »
hey blunt do u stil hav the boost solinoid hookd up?
vk turbo
Free Horsepower...
« Reply #1324 on: December 23, 2004, 02:42:01 AM »
the solenoid that you used could you activate it in the car or did you have to adjust it under hood cause my one is activated on a switch in the car
bluntsmoker
Free Horsepower...
« Reply #1325 on: December 23, 2004, 10:30:16 AM »
Madzilla -   Na the car came without the factory solenoid and was running unrestricted!
vk - its just under the bonnet now coz I find it works better with less piping, and i dont see the point if i dont want to adjust the boost all the time.    Having said that tho, Ill be buying an electronic unit of some sort in January
:mexican:
peter321
Free Horsepower...
« Reply #1326 on: January 12, 2005, 08:15:40 PM »
To get better power to weight ratio, the cheapest way is always reduce weight, anything not help you go faster, take it out, take the spare wheel and jack out, replace with a tyre puncture repair can.
madzilla
Free Horsepower...
« Reply #1327 on: January 27, 2005, 11:23:58 PM »
is there such thing as building up ur boost? if so how? i hav an auto r33.
boosting
Free Horsepower...
« Reply #1328 on: February 10, 2005, 01:20:12 PM »
i heard 15 max 4 r32 turbos but they can take a beating a m8 had his free boostin an it hit 30 blew his intercooler piping off now his turbo screams like a pig
zique
Free Horsepower...
« Reply #1329 on: February 17, 2005, 01:45:35 PM »
how do you mean by "free boosting" boosting?
andrewrr
Free Horsepower...
« Reply #1330 on: February 17, 2005, 06:08:45 PM »
no wastegate!!!! :nuke:
Lobster
Free Horsepower...
« Reply #1331 on: February 22, 2005, 09:54:01 PM »
gtstCruiser: check ur afm sensor for damage (little wire inside). if its broken then your afm is f*cked, if its got crap on it, clean it with some electrical cleaner. then, if its burnt, then its probobaly f*cked.
all it takes is something small to get stuck on it and it will burn. that little wire gets pretty dam hot. thats why it has a mesh on the end of it, dont remove it...
boosting
Free Horsepower...
« Reply #1332 on: March 10, 2005, 08:22:16 PM »
thats a secret
RB20DETdude
Free Horsepower...
« Reply #1333 on: March 28, 2005, 06:23:53 PM »
UNFAMILIA DONT NO WAT THE HELL UR DOIN I CAN SPEED CUT MY GTS4 A DOZEN TIMES A DAY ON DA WAY TO WORK ITS ALL RELATIVLY EASY EVEN IN MY STANDARD CAR
R32 GTS-T Coupe RB30DET .
    Lifes a burnout- smoke it up
vk turbo
Free Horsepower...
« Reply #1334 on: April 07, 2005, 10:06:34 PM »
to stop ya afm from getting screwed i reckon piss it off altogether and put in a after market computer
