Author Topic: R33 Boost Query  (Read 1628 times)
R33 Boost Query
« on: June 10, 2001, 03:31:52 AM »
primera1
(5/14/01 6:52:33 pm)
Reply  R33 Boost Query
 I've got a R33 GTS25T. When I first bought it, it was running 7psi boost. I've since added a K&N pod filter, and a 3" mandrel bent exhaust, but the boost remains at 7psi max. In frustration, I unplugged the wastegate soenoid, and gave it a quick run, and the boost still remained at 7psi, what the hell is wrong?? Is my turbo buggered, or is the factory blowoff valve preventing higher boost?? please help me!!
GraemeWi
(5/14/01 7:03:08 pm)
  Re: R33 Boost Query
 My understanding is that the solenoid is used to pulse the wategate supply line. There still is a wastegate and diaphragm used in the R33 - so it will be that the wastegate spring pressure is set at 7 psi.
I've got a Turbosmart bleed valve system that has replaced the factory solenoid (binned) as I was only getting something like 5 or 6 psi.
Sky Jack
(5/14/01 11:29:16 pm)
Reply  Re: R33 Boost Query
 Does this happen on a R32 as well??
skyzerr33
(5/15/01 12:53:26 am)
Reply  R33 boost
 Ok i'm open to be told i'm wrong as its very likely that i am, but a pod filter and exhaust r going to improve your air flow and not increase your boost. To do that u have get a bleed valve and set it accordingly, also i've been told a larger intercooler capacity will increase boost as well as allowing higher boost levels to be set.
GraemeWi
(5/15/01 12:28:32 pm)
  Re: R33 Boost Query
 Sky Jack, only the R32 GT-R's have the solenoid. The rest of the R32's just have a hose between the turbo outlet and the wastegate diaphragm.
GW
lochy25t
(5/15/01 2:07:13 pm)
Reply  Boooost
 As far as I know, the solenoid switches from about 6psi to about 8psi when you rev over 5000rpm ( it certainly does in my 25t anyway ) Have you guys had any probs with fuelcut? My car has a larger throttle body, cat back exhaust (3.5" with cat removed) and K&N panel filter. On a cold night over 5000rpm it will hit the fuelcut
Does anyone else have this problem?
I think the fuel cut is only marginally above 8psi.
Anyone know how to remedy this?
primera1
(5/15/01 7:09:49 pm)
 To my understanding, adding a free flowing exhaust system(compared to the factory one), there was less back pressure on the turbo, and hence boost pressure rises slightly(or does it just spool up faster)
Needajapcar
(5/15/01 7:54:10 pm)
 lochy25t
You may have a leak somewhere in the i/c piping. And yes boost will rise to 8psi with exhaust and intake.
primera1
(5/16/01 6:58:21 pm)
 Shouldn't unplugging the wastegate solenoid lock the wastegate closed??
Needajapcar
(5/17/01 1:59:44 pm)
 primera1
Factory boost control the r33's is a little different from other cars. The the solenoid (little canister thing with an inlet and outlet) actually bleeds pressure from the "i/c piping -> wastegate actuator (near the turbo) hose (has a T piece in it)". So unplugging the wiring to the solenoid will not do anything except to hold the wastegate wide open (no pressure is bled off). Do you have an aftermarket boost gauge? If so I can let you know how to easily get a little more boost.
primera1
(5/17/01 6:44:17 pm)
 Hi Needajapcar,
I have a autometer lite boost guage installed, how can I lift the boost a touch??
Ninja25t
(6/8/01 2:19:20 pm)
 primera1
Check out if the factory boost bleed solenoid is actually working. Its designed so that it will open and bleed off boost from the waste gate actuator lifting max boost from 7 to 10psi above certain rpm/throttle points. It stays closed if there any detonation etc. As a quick check disconnect the line to the solenoid and take it for a quick test drive. Boost should come up and you will hit the boost cut at 12psi, otherwise you have some other prob.
My factory boost bleed solenoid was stuffed and I was only getting 7psi. Robin at Torque Performance simply disconnected and inserted a 3/16" plastic garden irrigation type T piece in the end to provide some back pressure and boost was up from 7 to 10psi = 10kw at wheels as standard car.
Shane Moore
