Author Topic: C33 Laurel RB20DET  (Read 6058 times)
mrmeal
C33 Laurel RB20DET
« Reply #15 on: October 07, 2004, 01:38:07 PM »
or you could buy an RSM and ammend the wheel size in it's internal setting to something like 120% of the real world setting.  I did that while my diff ratio was stuffing up my speedo needle.  Swapped diffs to an LSD and the diff ratio was bang on the mark again, so needle went accurate.  Apparently you can get an adapter box type thing made up, but the crowd I talked to about it, wanted something like $200 (I can't be perfectly sure on that price as was ages ago), and would take several hours on their hoist.  try to get a skyline LSD as life will be peachy then.  But just so you know there are ways to get the adjustment done.
If you try and don\'t succeed, cheat. Repeat until caught. Then lie.
http://nzhondas.com
http://www.rotarymotion.co.nz/forum/
Team Geezer
mrmeal
C33 Laurel RB20DET
« Reply #16 on: October 07, 2004, 02:08:22 PM »
oops sorry, better elaborate in case you didn't know....
RSM, Rev Speed meter put out by Apexi.
http://nzhondas.com
Team Geezer
coldturkey
  • Guest
C33 Laurel RB20DET
« Reply #17 on: October 07, 2004, 02:31:51 PM »
i was under the impression the mechanical LSD he has is better than a skyline LSD
pure_methamphetamachine
    • http://geocities.com/psyminr34
C33 Laurel RB20DET
« Reply #18 on: October 08, 2004, 03:29:14 PM »
Why cert it? You will be pushing to find someone who will fail it. My car has needed a cert for the last 4 warrants.
Only needs a cert for the engine, gearbox cross member, brakes, hubs, chassis, suspension, instrument panel, exhaust, driveshaft...
Passes every time.
pure methamphetamachine
Team Sleeper
580.5kW @ Wheels
RIP Chris Leicester.
25 / 11 / 2007
I will never forget.
I will always keep my promise.
Zanthiath
    • http://www.dimension7.co.nz
C33 Laurel RB20DET
« Reply #19 on: October 09, 2004, 03:42:49 PM »
Basically all youll really need a cert for is coil-overs.
Most warrant places including testing stations are either pretty easy or dull.
pure methamphunmachine
Team Sleeper
coldturkey
  • Guest
C33 Laurel RB20DET
« Reply #20 on: October 10, 2004, 11:19:52 AM »
Im just waiting for him to get the gearbox back fixed, but Im still not convinced its going to be a trouble free car
Zanthiath
C33 Laurel RB20DET
« Reply #21 on: October 11, 2004, 04:24:06 PM »
Thought id post a pic.
If your interested in that car, and he has the gear box out, make sure a heavy duty clutch is going in, if not and you are going to buy put one in.
Team Sleeper
