Author Topic: Rb20det and 5spd in S13?  (Read 5798 times)
Viktro
  • Guest
« Reply #15 on: January 13, 2005, 06:46:48 PM »
Quote
Originally posted by GT-R Ben
:laugh:
RB30DET in S13.
Lowered 10mm and a mad bonnet, should do it just fine..
Bonnets are overrated ;). Gotta see your S13 sometime Ben, sounds like it's coming along alright :).
drift_and_slide
  • Guest
« Reply #16 on: January 15, 2005, 03:40:31 PM »
wouldnt a laurel x member fit? or cefiro? considering they are based on a silvia chassis and have RBs in them
Robert
    • http://www.japwheels.co.nz
« Reply #17 on: January 15, 2005, 08:20:14 PM »
Quote
They're the same as a Skyline ones.
RB26DET S13 200sx
471rwhp at 1.4bar
11.08@123Mph
rudeboy
  • Guest
« Reply #18 on: March 07, 2005, 03:35:28 AM »
i run an rb20det in my s13. i used all the stock r32 equipment. everything bolted up fine. i added spacers to the hinges on my hood(bonnet) and it shuts. the shifter is a little closer to the radio. the motor does sit a little high and forward. but i'm used to it now. the sr/ka driveshaft will slide right in. just have to swap out the RB speedo cable to the sr/ka electric speedo sensor
GT-R Ben
  • Guest
« Reply #19 on: March 08, 2005, 02:25:33 PM »
Reinstalled my engine in the weekend.
With the engine lowered and the reinforcing removed from the bonnet, it almost closes with the RB30 :)
Only going to need a slight lump.
Robert
« Reply #20 on: March 08, 2005, 02:35:16 PM »
Sounds good Ben.  What method did you use to lower your engine?
I really want to get mine going in time for the 4 and rotors but I'm not sure if there's enough time to get it done and all certed etc.
RB26DET S13 200sx
471rwhp at 1.4bar
11.08@123Mph
hybrids14
  • Guest
« Reply #21 on: April 08, 2005, 09:50:49 AM »
Hello GT-R Ben, what's the mods necessary to make the RB26 box fit the Silvia Chassis?  I have a S14 and I assume I still have to make a custom driveshaft, or do I?
cwald240sx
  • Guest
« Reply #22 on: April 08, 2005, 11:10:37 AM »
Your going to have to fabricate an entire front suspension if you want to make it AWD.  Otherwise just use a 25 tranny.
GT-R Ben
  • Guest
« Reply #23 on: April 08, 2005, 12:36:29 PM »
We were not talking AWD/4WD Cwald.
I have removed the chain and gears from the transfer case, had a plate welded onto the side.
In the S13 tunnel i needed to make some more room around the starter motor lump, and a small bit down the side. Apart from that if fits great.
I had to have the engine tilded back as far as possible and having the engine lowered 15mm helps. All it took was the heater hoses to be in the way and I couldn't tilt the motor back far enough to get the box on..
I will take some photo's.
I would have just used a 25T box.. but I had a spare RB26 box and it already had a busted transfer case. :) So it's better than spending $2000 right?
cwald240sx
  • Guest
« Reply #24 on: April 08, 2005, 03:24:09 PM »
Quote
Prolly so:D
hybrids14
  • Guest
« Reply #25 on: April 08, 2005, 04:18:39 PM »
Thanks for the quick reply.
The reason why I asked is because most people here in the U.S. have to purchase the GTR motor/tranny/harness/ecu combination and would require extra $ to purchase a RB25det box (which prices have gone up a lot and is getting harder to find)
Photos would really help, thanks Ben :)
1. On the RB25det/S14 swap, we needed custom driveshafts.  I'm wondering if you used custom driveshaft or ?
2. Can the Z32, GTR rear subframe bolt on to the S14? We in the U.S. is suffering from having to custom make axles since the stock S13/S14 axles break.  The Z32, GTR rear subframe(diff, axles, etc) is really cheap to obtain, and would handle the torque well.
cwald240sx
  • Guest
« Reply #26 on: April 09, 2005, 12:50:31 AM »
In our RB25 S14 we had to make a custom drive shaft because the S14 R200 diff takes a smaller yoke end than the RB25 tranny.  The S14 and Z32 non-turbo use the same diff but different subframes.  We also have a Z32 with about 550hp.  It started life as a non turbo car, so it has the smaller R200 diff.  We elected to keep it until it broke because of the better (for us) gear ratio.   That car has a OS Giken twin plate clutch and MT slicks.  It runs 1.65-1.69 60ft times and we have had no problems out of the smaller R200 diff.  They are bulletproof.
hybrids14
  • Guest
« Reply #27 on: April 09, 2005, 01:28:50 AM »
1. On the RB25det/S14 swap, we needed custom driveshafts. I'm wondering if you used custom driveshaft or ? The reason why I asked this question is because he's using the GTR diff, which means it's the same size yoke...
2. Can the Z32, GTR rear subframe bolt on to the S14? We in the U.S. is suffering from having to custom make axles since the stock S13/S14 axles break. The Z32, GTR rear subframe(diff, axles, etc) is really cheap to obtain, and would handle the torque well. What I'm referring to is the Z32 turbo, GTR subframe does it bolt right up(minus the rear hand brake mod) and it's the axles that break, not the R200 diff....
cwald240sx
  • Guest
« Reply #28 on: April 09, 2005, 03:42:40 AM »
Ahh!  gotcha on the axles.  I think the Z32 and GT-R have a wider track than the S14.  Not sure on that, so I'm going to leave this one alone and let someone else answer.  Bolting that R230 diff into an S14 subframe is going to be interesting if subframes wont swap.
hybrids14
  • Guest
« Reply #29 on: April 09, 2005, 06:40:50 AM »
Hrhr, that's why I'm asking GT-R Ben since he has the GTR diff..
Yeah, the wider track is perfect for my widebody conversion.  I know a guy that does make a kit for the installation of the R230 diff into a E36 BMW, but I'm not quite sure what setup he's running on the S14.  But I do know that he has the R230 diff and GTR axles.  Can't find him now... so the questions remain....
