Author Topic: rb30ed cars wanted for new web site  (Read 4591 times)
GDZ1LA
« on: September 13, 2005, 12:09:40 PM »
im building a we site based on rb30ed cars
please email me gdz1la@kol.co.nz if you have a rb30de or det dett powered car, im after anythink unique, non nissans, silvias old school datsun or similar, however anythink is welcome sky gtr cef laurel etc including os gikin kits
please include at leasted all high res
one exterior picture
2 engine bay pictures,
detailed engine specs
hp, max rpm boost, comp ratio used etc,
ecu and fuel system used iswell,
will be up and runninf with a few cars buy end of week
cheers
Shwartz_sticker
« Reply #1 on: December 06, 2005, 02:09:55 AM »
hate to brake it to you, but RB30's werent DET's. They are a single overhead cam engine.
They were just plain old RB30ET
Shwartz_sticker
« Reply #2 on: December 06, 2005, 02:12:56 AM »
my apologies, after looking at your website i see it wasnt a mistake.
GETLOW
« Reply #3 on: December 06, 2005, 12:19:11 PM »
when my rb30de with VVT is finishd. im hoping in time for the airtothere show in march ill send you pics and specs that you can put on your website. any advice/parts will be of great help. i have seen your website. its a nice looking site.
i stil only have the block bare tho :( cus im waiting on rb25de pistons, a flywheel so i can get the crank ballanced cus i dont think my rb20e gear box will handle. a head cus sounds like the one i was going to get is a bare head so no use for me
Shred Motorsport
67 Pharazyn Street
Lower Hutt, Wellington
(04) 569 7469
SafT
« Reply #4 on: January 14, 2006, 07:09:57 AM »
Quote from: BADR33
r33 rb25de pistons? (does it make a difference?)
GETLOW
« Reply #5 on: January 14, 2006, 11:19:22 AM »
yup they do. they increase the compression to 10.5ish insteada like 8 or 9.
my rb30de is alot further along now.
iv got almost all the parts needed to get it in the car and running bar clutch, starter motor, headers. i think thats about all i need.
the motor will be getting built up next week and i should have it in the car in about a month or so.
should be one of the first rb30de in the country that iv heard of and one of the first in to a r33 skyline that i know of..
Shred Motorsport
67 Pharazyn Street
(04) 569 7469
analyze
« Reply #6 on: January 14, 2006, 04:10:16 PM »
as soon as my rb30's in my r30 i'll send u sum info and guff :)
GDZ1LA
« Reply #7 on: February 12, 2006, 11:23:15 PM »
any newbee's?  i got 540hp 400kw on a stock bottom end last night , still has more potential
whats the gruntyest rb30det on stock bottom end? rips dont u claim 600hp?
i drift mine tho so mine not last longer the 10 sec lol
RIPS
    • http://rips@inspire.net.nz
« Reply #8 on: February 15, 2006, 09:00:16 AM »
Our 10 second engine that did a seasons racing and heaps of street work was 100% stock internals, even the RB25de head was untouched. It is still in a car now going strong more than 2 years after we stopped racing it.
600hp at all 4 was reliable and we never got to wind it up to "destruction" as everytime we went for a 9 the gearbox shat itself. The power level we ran to run low 10's was by no means leaning on it.
RIPS Racing
Worlds most powerfull RB30s, 7.8 @ 177mph in 240z and 7.26 @ 181mph in FED
Worlds quickest R34 street GTR, Worlds quickest 240z
RIPS FED current NZ record for DD/D with a 7.26 @ 181mph
PLEASE DON\'T PM ME, e-mail me
http://www.ripsracing.com  e-mail rips@inspire.net.nz
Cubes
« Reply #9 on: February 19, 2006, 01:48:55 AM »
I will post a few pics and throw mine on your web site.
I recently upped the boost and discovered lifter pump up over 5000rpm + a week later it ripped out 3rd gear from the rb20det gearbox. :(
I've got a set of low km gtr springs on the way, will have them checked and installed. I 'may' give it a shot as it doesn't appear difficult.
I'm also thinking of sorting out the oil restrictors, I stuffed up building the motor and had them both drilled out to the same size as the rb20det.
Any one know if one oil rb20det sized (2.4mm) restrictor will suffice? I run the rb25det oil pump that has quite decent oil pressure, definitely much higher than that of the rb20det pump.
The rb30 runs 1.8mm oil restrictors.
« Last Edit: February 19, 2006, 01:55:33 AM by Cubes »
SirRacer
« Reply #10 on: February 21, 2006, 12:23:49 AM »
ive got a matt black a31 in the build with rb30det. should hopefully be in the vicinity of 300/350 kws at the wheels
what turbo was 400kws on, very nice figure, when did it start to boost etc
GDZ1LA
« Reply #11 on: February 22, 2006, 11:12:09 PM »
turbo is t78 33d
not very laggy on a 3l either makes 1 bar buy 4500rpm with basic ign angles
was dynoed with a crappy 45mm chinese wastgate, which could hold the boost it creeps from 12psi (spring pressure) to 25psi at 6500rpm lol as they dont open enough, only made about 700nm engine or 2300nm wheels tho due to low boostat torque peak (was creeping up)
but...
 the motor poped at a drift even, trew a rod i belive the 6cyl big end seized first,
lots of things to blame..
first engine i ever built....:confused:
engine too hot? both oil and water temps,
oil viscocity to low (5w-30) (low oil press too thin)
and the boost creap to 30psi @7500rpm lol
o well i thought there were invincable lol
after stripping engine, (and finding conrod g pins on chassis rail)
and over 1l oil stuck in chassic rail
i found a mulched piston,
then i take the cradle off all the mains fried, but 4/6 big ends were ok)
i think it was mainly a oil problem i run a 1.2mm oil orriface so i doubt it ran out of oil, but oil temps were very hot and pressure low,
what is a safe rpm limit for drifting? i use jun crank collars and gtr oil pumps, and have alloy power enterprise crank pullys, whats best oil under that amount of stress, and what power can i safly take it too? the limit now is the bottom end,, or 800hp what ever comes first lol
anyway another 26/30 engine is in it , wth a greddy type r gate and ready for a re-tune... please boss:rolleyes:
foR
« Reply #12 on: March 01, 2006, 01:22:00 PM »
God I want one :p
RIPS
« Reply #13 on: March 02, 2006, 08:58:58 AM »
We';ve just about finished this one in a R33............
RIPS Racing
GETLOW
« Reply #14 on: March 02, 2006, 09:16:27 AM »
damn thats nice rob. its even got dirty old NOS?
thanks for all your help with my rb30
mine is finialy running!! once i finish getting everything done and it gets dynod ill send you a email GDZ1LA.
Shred Motorsport
67 Pharazyn Street
(04) 569 7469
