Author Topic: R34 GTR V-Spec TV Screen  (Read 998 times)
strutto
« on: June 14, 2001, 06:34:33 PM »
Hi All,
Does anybody have any info on getting the TV tuner in an imported R34 GTR V-Spec working with Australian channels?
I am sure it can be done - I just don't know how or by who!!
Any info would be greatly apprecaited.
Thanks.
GSR32
« Reply #1 on: June 14, 2001, 08:00:13 PM »
ummm, I am not sure if it will be possible. Japan most likely uses a different system to the Australian one.
eg. Australia/NZ use PAL B/G colour and 5.5MHz sound frequency
I am not sure what system Japan uses, but it may be NTSC colour, like USA, and use a different sound frequency.
Some TV's you buy now are multisystem, you may have seen them, they can do most systems. However, I will say that the R34 TV, will be setup for Japan system only.
I will find out more for you in the next day or 2, what system they are using and if it is possible.
Greg
NISMAN
SURE!!!
« Reply #2 on: June 23, 2001, 06:12:59 PM »
CHECK out on the internet about mod chips and things for playstation - it is the same thing, you just need a chip inside your TV so it can run in PAL mode I do Mod Chips for Playstations and would not mind trying your TV but you are too far away. Im in Auckland NZ.:(
