Author Topic: Stagefumer11's R30 coupe, UPDATE!!!  (Read 21927 times)
StageFumer11
« on: February 11, 2008, 10:46:49 PM »
Well since she has been off the road for along time, Ill do a progressive time line of when i first got her.. Man that was a few years ago now !!!
First lot, Parked up to Viv's old r32
After being lowered about 2 years later
This was after being painted. About a year ago.
« Last Edit: December 03, 2014, 11:27:45 PM by StageFumer11 »
1985 R30 Skyline Coupe
StageFumer11
Stagefumer11's R30 coupe, 56k go build a bridge!!!
« Reply #1 on: February 11, 2008, 10:46:39 PM »
Moding the factory intake manifold. Shaved and smoothed out. Ported with a 60mm throttle body.
 270cc vg30et injectors. Does make it look a lot cleaner
PowerAid bottle .. Dont diss it. thats 40hp there alone!
After a  bit of playing around
Now here is the depressing bit. Since getting it painted and driving her for around a year she
did fail her wof on brakes and a ball joint, That pushed me to finally take her off the road. These pics are what's seen on SDU. as some of you seen, But ill shorten it a lot
The engine bay is being painted with bed liner. Its a strong fuel and fire resistant ( and rust preventer).
The great thing is, it doesn't chip So i don't need to be scared with it. It has a great knuckle tearing texture!!.
A close up of what it looks like
The rest is pretty boring, But she is now the Main project. I'm just waiting for the rust to be removed,
 . Just waiting for mofo to finalize the shipping for my Body kit and other goodies :).
Lets say, Flares. Kit. Wider than normal. And low. Should look a treat :)
 Pannel work is happening yet again since i was ripped big time with the last paint job. Its not bubbling down the sides and on the roof. Pretty depressing a bit of money down the drain. But none the less. The project continues!!
StageFumer11
« Reply #2 on: February 11, 2008, 10:47:50 PM »
After working with the engine bay, Found large amounts of rust in the lower strut towers. R30's were really common for this. Thanks to Nissan no sealing and treating the skins. (using double skinning also) Front windscreen is due to be removed to get to a lot of surface rust which will progress to more if i leave it.
Attempted to remove the rear windscreen. Pity. That FAILED big time. 95% removed and it shattered.
With that, and a huge shower of glass. Well i had to take back a fair big of rust in the lower corners.... Up around the roof line.. and down the sides. Lucky its only small pin holes, which i can access from the inner skins.
Wish i had all the rust done, its really holding me back!!!!!
« Last Edit: December 03, 2014, 11:28:43 PM by StageFumer11 »
StageFumer11
« Reply #3 on: February 11, 2008, 10:48:22 PM »
UPDATE. got some progress. Rust is all fixed. and lookie lookie!  :lol:
StageFumer11
« Reply #4 on: February 11, 2008, 10:49:01 PM »
Finialy got to laying down the engine bay paint. + all the insides and boot.
3 coats before clear... Love the flat look.
« Last Edit: December 03, 2014, 11:29:04 PM by StageFumer11 »
StageFumer11
« Reply #5 on: February 11, 2008, 10:50:24 PM »
How about some clear... Definitly makes it pop!
« Last Edit: December 03, 2014, 11:29:17 PM by StageFumer11 »
StageFumer11
« Reply #6 on: February 11, 2008, 10:50:55 PM »
After letting the paint set for two weeks... (had to be safe) I hit the town and started installing all the new/rebuilt gear
Got the intercooler, oil cool and radiator mounted
I cleaned up. HOLY MOTHER I HAVE ROOM!
StageFumer11
« Reply #7 on: February 11, 2008, 10:51:35 PM »
L28 Motor fully rebuilt. Sure is purrdy
fully rebuilt head, with a mild port job. and custom rocker cover
My custom Pallnet fuel rail from the states
StageFumer11
« Reply #8 on: February 11, 2008, 10:52:42 PM »
Been working on the outside... Fitting the flares and side skirts. Bit of work involved in the middle of joining the sideskirts where i had to lenthen them
Just put 90% of the inerior back in.. Id have more pics my my partner.. well she droped the camera in water :(
« Reply #9 on: February 11, 2008, 11:02:13 PM »
Awesome, thanks for sharing. :)
That turbo looks huge. :eek:
Engine bay looks mint, can't wait to see the exterior when it's done. :)
StageFumer11
« Reply #10 on: February 11, 2008, 11:09:09 PM »
Turbo is a HOLSET hx40w..... 60mm inducer 83mm exducer. .89a/r exhasut side., think it is a 89mm exhasut wheel. good for some serious power :)
« Reply #11 on: February 11, 2008, 11:16:39 PM »
Dude! ...... :notworthy
All I have to say about that!
« Reply #12 on: February 11, 2008, 11:28:38 PM »
Got to be at least a 500hp+ turbo??? :eek:
What style of rims have you decided on, as it looks like they are going to be wide and maybe deep dish???
« Last Edit: February 27, 2011, 10:05:15 PM by gtsr »
StageFumer11
« Reply #13 on: February 11, 2008, 11:32:56 PM »
should be 600+ turbo. ;)
Sport max sm962's
http://www.sportmaxwheel.com/sportmax_962.shtml
with gunmetal center
« Reply #14 on: February 11, 2008, 11:58:12 PM »
Wow. :eek:
So I pressume 18" ???
