Author Topic: Stagefumer11's R30 coupe, UPDATE!!!  (Read 19185 times)
NIS R31
    • http://www.boomspeed.com/r31skyline/NISR31-04.JPG
Stagefumer11's R30 coupe, 56k go build a bridge!!!
« Reply #31 on: February 14, 2008, 12:22:56 PM »
yeah pete those are the ones, would be good if they made dished 18's :)
mmmmmm
« Last Edit: February 14, 2008, 12:26:14 PM by NIS R31 »
Regards,
Lonnie
Orion
    • http://www.tx3nz.com
« Reply #32 on: February 14, 2008, 08:03:34 PM »
hmm I should really get mine repaired and repainted then stick them on something...
1983 DR30 Skyline RS-X (x2)
2 door coupe || 4 door sedan
Mr GTS4
« Reply #33 on: February 16, 2008, 12:43:01 PM »
Looking mint there Nick.
Glenn
StageFumer11
« Reply #34 on: February 18, 2008, 10:53:39 PM »
Been doing a little bit of work..
More flare work.. Sitting better front is bonded just working with the rear. front flares have been squared off. I need to glass behind them since they arnt overly beefy :(
1985 R30 Skyline Coupe
« Reply #35 on: February 19, 2008, 10:32:25 AM »
So your not going to fiberglasss the outside of flares to body???
It should blend better once fiberglassed to the body.
StageFumer11
« Reply #36 on: February 19, 2008, 05:54:29 PM »
Im keeping the sharp line of the flares and the side skirts. Keeps it in line with the older style.
Flares are bonded to the gards. You match up where you want everything. Bolt it in ect... Shave what you need to. Remove it and put down Pannel glue. Its higly flexable, strong, sandable, paintable. Used alot for installing Van side pannels. No welding required. Fantastic stuff. After it sets. You remove the screews, Easy and simple.
I will so a thin skim of bog/resan mix to tidy some lines up
Lith
    • http://teamlurkracing.orcon.net.nz
« Reply #37 on: February 19, 2008, 07:57:42 PM »
Nice one Nick - coming along sweetly!   Look forward to seeing how it comes out :)
Don't forget to sort something out with the Holset turbo re: wastegate, what was the gate pressure again - 2bar or something? haha
"The only true wisdom is in knowing you know nothing."
  --  Socrates
... thanks for all the fish
« Reply #38 on: February 19, 2008, 08:23:43 PM »
I thought it might be like what is done with widebody fenders on the rear with screws, fibreglassing to blend with the body.
Looking at some oldschool flares in photo's, they seem to be bolted on with the bolt holes still showing.
What your doing, by what looks like bogging the holes, looks interesting and different. Can't wait to see the final result. :)
« Last Edit: February 27, 2011, 10:07:15 PM by gtsr »
StageFumer11
« Reply #39 on: February 19, 2008, 09:21:17 PM »
hahaa. factory gate setting is 49.5psi!!!!!! pretty extream!. Got a external wastegate, Going to use a spacer unit..
The flares. yeah.. Going to be a smooth look but with the sharp lines. An yes going to bog the holes. But then again the look of fake bolt heads really takes my fancey
drtydog
« Reply #40 on: February 21, 2008, 09:36:27 PM »
prob won't b interested but there's a cusco 1.5 lsd unit on trademe to fit older skylines and silvia's pretty expensive tho...you prob have your diff sorted anyway lol
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Other/auction-141900321.htm
StageFumer11
« Reply #41 on: February 21, 2008, 10:28:33 PM »
heck that would be nice. out of the price range for anything that one!. Good thing to see it fits long nose r200's.
I do have my diff sorted somewhat, Going to use the 280z diff i have. Possibly weld it. Either way i can fall back onto my factory r200..
drtydog
« Reply #42 on: February 22, 2008, 06:52:19 PM »
280z diff will be an open r200 anyway won't it? easy fixed tho, just pull the welder out lol
StageFumer11
« Reply #43 on: February 23, 2008, 11:41:11 PM »
yes open diff, But atleast more driveable than an a locker
drtydog
« Reply #44 on: February 25, 2008, 09:47:05 PM »
that it tru...was your coupe factory lsd? as alot of the auto coupes i've seen seem 2 b factory lsd. lust have one lock diff and one open and switch around when u need 2 lol
