Author Topic: Wiring problems on a31 with skyline loom  (Read 1916 times)
SirRacer
« on: March 24, 2008, 08:34:09 PM »
Hi There,
Ive encounted a problem when using an r32 gts25 loom on my a31 rb20e cefiro. We need to use this loom due to running an rb30det (r32 head) so naturally have used the loom.
The skyline loom however looks to have different plugs to connect the headlights whereas the cefiro has a basic plug.
Ive ditched the cefiro loom a long time ago, and now need to know what others have done in this situation.
In another loom (rb20de) there is only one large plug to connect the headlights and ....
The first 2 pics are the plug which connects on the cefiro, and the others are of the loom we are using. If we manually need to wire from the pins to the headlights, what is the other big plug for? Where will that plug in?
Thanks
Pics
http://www.skylinesaustralia.com/forums/index.php?act=attach&type=post&id=149805
http://www.skylinesaustralia.com/forums/index.php?act=attach&type=post&id=149806
http://www.skylinesaustralia.com/forums/index.php?act=attach&type=post&id=149807
http://www.skylinesaustralia.com/forums/index.php?act=attach&type=post&id=149808
http://www.skylinesaustralia.com/forums/index.php?act=attach&type=post&id=149809
projects
« Reply #1 on: September 01, 2009, 10:19:44 AM »
hey man what'd you end up doing about this issue?? I think im going to hit the same deal when i wire mine up.
Rb26det Holset S13 Track car.
BigJK
« Reply #2 on: January 29, 2010, 08:46:27 PM »
hey guys have got a diesel c33 laurel converted to 20det using an r32 rb loom i wired it up and can give you a few pointers if need be have some simple to follow wiring diagrams 2 if needed, cheers.
