Author Topic: r32 auto gearbox cross member  (Read 874 times)
Looney_Head
« on: June 08, 2009, 06:53:44 PM »
Hi just wanting if some one can post a pic of a r32 auto gearbox cross member?
Kthnxbye
god is just an imaginery friend for grown ups
GETLOW
« Reply #1 on: June 09, 2009, 12:59:46 PM »
phill i have found a few more auto crossmembers at work. if you have tryed that s15 one you could bring it out and say where and how far its out.
1JZ VVTI R33 using a custom RB25DET gearbox (almost running)
Shred Motorsport
67 Pharazyn Street
Lower Hutt, Wellington
http://www.SHREDMOTORSPORT.co.nz
(04) 569 7469
Looney_Head
« Reply #2 on: June 09, 2009, 04:35:42 PM »
ah thanks Geoff,
i checked the S15 one and its the same as the R32 manual one :(
gtsr
« Reply #3 on: June 09, 2009, 06:31:15 PM »
As far as I know for manual conversion on R32 auto chassis, you use a S13 manual crossmember.
Looney_Head
« Reply #4 on: June 09, 2009, 06:40:39 PM »
i am doing a rb25det gearbox conversion on my originally manual Rb20det
gtsr
« Reply #5 on: June 09, 2009, 07:04:28 PM »
As far as I know RB25DET gearbox bolts into a factory R32 auto chassis without problems, even uses the stock RB25 gearbox mount on I think was S13 manual crossmember. It was fitted after R32 manual gearbox was fitted.
But the crossmember is totally out on a factory R32 manual chassis due to crossmember mounting holes on factory R32 manual chassis that are forward more (someone said 50mm forward???) and requires a custom made crossmember.
« Last Edit: June 09, 2009, 07:09:09 PM by gtsr »
Looney_Head
« Reply #6 on: June 10, 2009, 08:33:23 AM »
yep that about sums it up. now off to make some custom tabs.
will post some pics once done for those that care
gtsr
« Reply #7 on: June 10, 2009, 03:15:42 PM »
Looney_Head
« Reply #8 on: June 10, 2009, 04:40:14 PM »
S13 won't work
gtsr
« Reply #9 on: June 11, 2009, 01:31:46 PM »
On a manual chassis the S13 manual crossmember probably won't fit.
Erelyes
« Reply #10 on: June 16, 2009, 08:43:41 AM »
R32 manual and auto gearbox xmembers are exactly the same.
Silvia ones are different
Did you try a manual or an auto S13 one looney?
- Pete
Looney_Head
« Reply #11 on: June 16, 2009, 10:33:18 AM »
Hi Pete,
ones i have tried are:
R32 Manual
R33 RB25DET Manual (same as R32)
S15 Auto same as R32
R32 RB25DE Auto (different to all, close to the bolt holes on the chassis but doesn't fit the gearbox)
don't know where gtsr started talking about s13 ones from but have not see one.
i am going to have to make up some tabs and have them welded to the RB25DET cross member
gtsr
« Reply #12 on: June 16, 2009, 01:11:55 PM »
From what I understand, a S13 manual crossmember is used when fitting a manual transmission into a auto chassis due to I gather is the different length of gearbox.
If you used a R32 manual crossmember on auto chassis, it supposedly doesn't line up with manual gearbox mount.
I was thinking if you turned the S13 manual gearbox crossmember around, does it make up that 50mm and line up with RB25DET gearbox mount. But you said it doesn't.
Looney_Head
« Reply #13 on: June 16, 2009, 09:28:31 PM »
i don't know how people can say just turn the mount around, one side is higher then the other
Erelyes
« Reply #14 on: June 21, 2009, 03:49:20 PM »
Quote from: Looney_Head;484254
Hi Pete,
R32 Manual
Hi Looney.
That's odd. I have had R32 RB20DE auto, R32 RB20DE manual, R32 RB20E auto, R32 RB25DE auto... all 100% the same.
I do know there are letters on each crossmember which identify them, "A" "B" and "C". Can't remember which are which, but have a look at what letters are on your existing ones and go from there.
Note, from memory you have to remove the gearbox mount to see the letter on the crossmember.
Turning the crossmember around is more dodgy than using 2 of the holes! It's way askew if you do that.
- Pete
