Author Topic: Looney_Head build  (Read 17634 times)
Looney_Head
Re: Looney_Head build
« Reply #195 on: September 09, 2015, 08:58:45 AM »
From Sinco? What's that monster turbo?
yeah looking at a sinco one, only other one i would trust would be 6boost.
its a Borg Warner S300 83/75 with a twin scroll .91 housing should do the trick. from here: http://www.theboostlab.com/store/products/S300SX3%252d60-.91-A%7B47%7DR-%28Straight-Compressor-Outlet%29.html
god is just an imaginery friend for grown ups
Ryeoon
« Reply #196 on: September 09, 2015, 10:13:25 PM »
Wow!! Will be a mean bit of kit when complete.
Looney_Head
« Reply #197 on: September 10, 2015, 07:47:31 AM »
hopefully, its been a long time dream, i have had the block for 10 years now.
Looney_Head
« Reply #198 on: January 11, 2016, 08:39:20 AM »
so haven't done to much on the car lately due to life getting in the way. but over Christmas I managed to get some work done.
swapped over the clutch master cylinder to avoid fouling the intake manifold:
this is the master cylinder i used: http://www.trademe.co.nz/motors/car-parts-accessories/nissan/clutches/auction-1010833211.htm
also finished running the VCT oil feed line:
Note for anyone running a Exedy triple plate clutch (ie NM033SR) you will need to change your clutch release bearing carrier to a shorter one that puts the bearing closer to the clutch fork, part number 30501-02C74:
Then this weekend i had some mates over and we made all the jigsaw bits into one bigger bit:
to pretty to hide :(
and in, with turbo sitting there for effect:
and because we could:
next to do is get exhaust manifold sorted.
Looney_Head
« Reply #199 on: March 11, 2016, 10:43:38 AM »
so more parts arrived. i have started sussing the fuel system which is fun.
and i ordered a Sinco manifold which has finally turned up:
now to finish the fueling stuff then pay someone to makes some intake pipes and a dump pipe. then wiring and an ecu
Looney_Head
« Reply #200 on: April 19, 2016, 08:02:06 AM »
another bit to the puzzle acquired:
should be useful when its all done.
Ryeoon
« Reply #201 on: April 19, 2016, 05:33:49 PM »
Coming together nicely.
Looney_Head
« Reply #202 on: August 08, 2016, 08:18:16 AM »
hi all, i have slowly been working on the fuel system and as of yesterday it looks to be complete.
have fired up the pumps and there looks to be no leaks which amazes me :D
next is to get it back on its wheels then off to my mate who is going to do all the remaining pipe work, after that i can sort the wiring and hopefully make some brmmm brmmm noises.
pics of fuel system:
Looney_Head
« Reply #203 on: May 24, 2017, 08:11:51 AM »
Man its been a while since i updated this the car went to my mates place getting the fabrication done and came back and now the long task of getting it finished has started.
first job hang the exhaust:
next up was mounting the intercooler and piping:
intake piping:
and dump pipe/wastegate pipe:
also picked up a couple of driveshaft loops for a R32 sedan:
a Fenix radiator was purchased:
power steering was sorted:
Coolant line was sorted:
LS coil on plug setup has been mounted:
Exhaust has been wrapped and installed for the final time:
hot side of the engine is fully assembled, oil feeds and returns, dump pipe the lot:
Switch panel in progress, and new 3 bar map sensor:
and Adrian (Pizzaboy) has made excellent work on the wiring, still dash and engine loom left, but getting there slowly:
oh and have ordered a Haltech Street dash so that will look nice in the car when it turns up.
« Reply #204 on: May 26, 2017, 09:24:38 PM »
On the road in 2017?? :D
Looney_Head
« Reply #205 on: May 29, 2017, 07:59:51 AM »
fingers crossed. the months just keep flying by at the moment :(
Looney_Head
« Reply #206 on: June 15, 2017, 08:42:20 AM »
some more progress, Fuse/relay/ecu panel is complete and all heat shrinked.
and in the car:
and new toy turned up, currently having a mate 3D print a mounting system for it:
next is start the under dash wiring for things like lights, indicators, horn etc. fun times..
Looney_Head
« Reply #207 on: October 27, 2017, 01:31:41 PM »
after many years and more dollars then i want to keep track of...
https://www.youtube.com/watch?v=kdoRuvwTSO8
success. not ready for the dyno yet, but will be very soon.
Looney_Head
« Reply #208 on: March 07, 2018, 01:53:00 PM »
and finally made it to the dyno for a quick 14psi run
https://www.youtube.com/watch?v=Fhf1RIKshUs
yay 500whp :D
« Reply #209 on: March 08, 2018, 10:32:58 AM »
Sounds great. What is your ultimate estimated max boost?
