Author Topic: S14 RB25DET Engine mounting  (Read 4129 times)
stageebot
    • http://www.facebook.com/search/?q=Lance+winters&init=quick#/profile.php?id=666096630&ref=sea
« on: April 28, 2010, 03:22:02 PM »
Hey Guys
This has probably been covered before but I cant seem to find any info on here.
I am thinking about buying an s14 silvia and eventually re-powering it with an RB25DET. and I am curious to know whether there is any kits available in nz to make bolting the engine in easier I have seen that in the us there is a syko performance, mounting kit which make the surgery a lot more easier its just a matter of bolting it in. are there similar kits available in nz? if not where is a good place to get the fabrication done? when I eventually do the re-power so it makes the conversion as painless as possible.
Any help would be appreciated
Cheers. Lance
« Last Edit: April 28, 2010, 03:24:11 PM by stageebot »
Dino
« Reply #1 on: April 28, 2010, 03:54:28 PM »
i will be watching this haha i have just been offer a s14 cheap and am thinking of stripping the cef and doing the same,and were both in the naki
« Reply #2 on: April 28, 2010, 04:39:30 PM »
I could be wrong but isnt an RB cross member used? I am pretty sure it is in the S13 at least.... So anyone know if the S13 and S14 cross member is interchangable? Good ol' Nissan, its just like Lego!
BenEn
« Reply #3 on: April 28, 2010, 07:28:03 PM »
c34 and c35 laurel crossmember could fit as s14 and s15 suspension is the same. I'm not 100% sure tho but if anyone has the crossmembers measurements for a s14 I could compare the measurements with my c35
stageebot
« Reply #4 on: April 29, 2010, 12:18:44 AM »
Yea from my research I have found out that you use the R33 crossmember and you can use the stock RB mounts but the engine sits a bit to high and forward a lot more than if you use custom mounts so thats where i found out about the syko performance mounting kit that is available in the USA but that would be rather expensive 2 get shipped to nz so thats why i was wondering about whether nz has a similar kit.
heres a link to a site which explains how its done with the syko mount kit:
http://www.superstreetonline.com/techarticles/130_0703_sr20_rb25det_swap/index.html
I dont no why this isnt done more often in S14s its seems like a awsum alternative to the SR20DET conversion.
So yea my question still stands. :D
« Reply #5 on: April 29, 2010, 12:48:52 AM »
Ahh yes, too far forward would definitely cause some handling issues! Surely an engineer could fabricate/modify something to make it sit back a bit. Its just got to be well done to pass cert.
To remove the height issue, get a front facing plenum :) Or look into custom engine mounts, Nolathane do custom mounts I think.... Maybe use your mounts but get them made to half the height, just an idea
paulbagz
« Reply #6 on: April 29, 2010, 09:36:10 AM »
whoa my first post on this forum.anyway ive got a rb25det powered s14 club car that ive built up from sr20de auto.i used r33 x member and mounts and it fits under the bonnet by about 2mm.any questions you have just hit me up. cheers paul
stageebot
« Reply #7 on: April 30, 2010, 12:25:24 AM »
Oh kool that makes it a lot easier than custom mounting does it still handle good with the R33 mounts and crossmember not adverse effects? cause when i do it i still want to daily drive it thats my ultimate goal
paulbagz
« Reply #8 on: April 30, 2010, 08:15:50 AM »
i have never had any understeer problems in the dry but have had the car well setup.in the wet on sh*t tyres it does get abit scary if your pushing the car
stageebot
« Reply #9 on: April 30, 2010, 12:12:45 PM »
Quote from: paulbagz;493979
kool kool I should imagine it would. For me as long as it will be daily drivable  il be happy. Was there anything that you had to customize like gearbox mounting ?
« Last Edit: April 30, 2010, 12:20:58 PM by stageebot »
paulbagz
« Reply #10 on: April 30, 2010, 06:18:07 PM »
yea my cars full racecar and could drive it everyday.im running 25det box so had to make gearbox mount but if your running a 20det box they bolt right up with the right g box member
stageebot
« Reply #11 on: April 30, 2010, 10:09:28 PM »
Quote from: paulbagz;493988
awsome sounds a bit easier than i thought it would be when i get right into doing it il have to hit u up on things that im having trouble with. il post on here when i get an s14 2 show u and everyone my canvas as well.
cheers man. :D
Lance
paulbagz
« Reply #12 on: May 01, 2010, 03:28:22 PM »
allgood dude ive just got anotha silvia today(the 3rd one lol) and the rb does feel abit quicker but is heaver up front
datlow
« Reply #13 on: June 13, 2010, 07:43:51 PM »
pretty sure i saw some on trademe that are cut down so you can fit a rb30 (as taller) under the bonnet so might be the go
