Author Topic: My 180 Build  (Read 17852 times)
R32ONP
My 180 Build
« Reply #30 on: September 21, 2010, 02:04:26 PM »
ah yes does some of the skylines come with a manual rack?
Steer from the rear ..... Drop it like its hot !!!
pure_methamphetamachine
    • http://geocities.com/psyminr34
My 180 Build
« Reply #31 on: September 21, 2010, 03:19:21 PM »
Custom vacuum box to feed each cylinder, brake booster, MAP, BOV etc:
With the exception of 6 coil -> plug leads, engine and engine bay fully rewired (yes, it is all there... :)  ):
Now to finish behind the instrument panel etc...
pure methamphetamachine
580.5kW @ Wheels
RIP Chris Leicester.
25 / 11 / 2007
I will never forget.
I will always keep my promise.
samos69
My 180 Build
« Reply #32 on: September 21, 2010, 03:49:33 PM »
Looking sharp! Can I ask where you got the sleeved 0 (4?) gauge cable to relocate the battery from the engine bay as I'm on the hunt for some.
Sam
Beginning build phase S1DWYZ MkII in progress.
My 180 Build
« Reply #33 on: September 21, 2010, 04:10:16 PM »
It is normal 0GA cable with a special sleeving that looks pretty. We all call it Bling Bling Conduit :P
You can get in NZ for like $20 a metre, so I bring it in in bulk from the USA as it's half the price. I am doing another bulk order in a month or so.
580.5kW @ Wheels
25 / 11 / 2007
samos69
My 180 Build
« Reply #34 on: September 21, 2010, 04:16:53 PM »
So it's just stranded power cable - basically the stuff you use for stereo setups? How does that handle extended periods of cranking the engine over? I was under the impression you should use something with larger strands (such as welding cable) when placing the battery so far away from the starter (not saying that is correct I'm just trying to learn something here!)
Sam
Zanthiath
    • http://www.dimension7.co.nz
My 180 Build
« Reply #35 on: September 21, 2010, 08:42:08 PM »
The cable i used is proper 70mm2 power cable, designed for 400v plus.
with a direct 4 gauge feed to starter motor from battery.
pure methamphunmachine
Pandaemonaeon
My 180 Build
« Reply #36 on: September 21, 2010, 09:05:24 PM »
Audio setups will draw just as much, if not more in some cases than a starter motor will, so there is no problem running audio cable.
pure methamphatamachine
samos69
My 180 Build
« Reply #37 on: September 22, 2010, 04:41:13 PM »
Quote from: Pandaemonaeon;510709
Good to know, I've got plenty of 4 gauge stuff lying around from old audio setups to use.
The kicker distribution blocks look good, do you run a (kicker?) circuit breaker down by the battery or fused?
Sam
My 180 Build
« Reply #38 on: September 22, 2010, 04:59:24 PM »
Fuses. No circuit breakers.
But fuse for what?
580.5kW @ Wheels
25 / 11 / 2007
My 180 Build
« Reply #39 on: September 22, 2010, 05:28:38 PM »
And the smaller the strands withing the cross section the better the cable. With the exception of 1 SOLID core, the smaller diameter the inner strands that make the core are, the less void space you have, hence more metal.
580.5kW @ Wheels
25 / 11 / 2007
samos69
My 180 Build
« Reply #40 on: September 22, 2010, 06:18:57 PM »
Quote from: pure_methamphetamachine;510907
But fuse for what?
I normally fuse amp setups in case of a short as you're running a constantly live wire the length of the car so figured it'd be the same for relocating a battery.
Sam
My 180 Build
« Reply #41 on: September 22, 2010, 06:27:59 PM »
There is a main fuse at the front for the feed from the alternator to the battery. Every system also has it's own fusing. Only the starter does not, but it is triple insulated.
580.5kW @ Wheels
25 / 11 / 2007
Zanthiath
My 180 Build
« Reply #42 on: September 24, 2010, 10:55:13 PM »
I chose Mr P to do the wiring cause he's damn good and very very fussy and maticulous.
Everything he does is over engineered
skidMark
My 180 Build
« Reply #43 on: October 15, 2010, 12:46:21 PM »
Quote from: Zanthiath;511187
After catching upo and seeing progressi think fresh pics for the masses dude, i'm blown away by how far its come so quickly.
P seriously man, if only i could afford you for an hour :laugh:
Not too long 'til you can hit the streets Cam, u've earnt it bro.
Every site needs a token bogan:
Quote from: gts-4r;541051
hit it with a hammer if it still doesn\'t work then its an electrical problem.
My 180 Build
« Reply #44 on: October 15, 2010, 04:29:09 PM »
What do you need done skiddy?
580.5kW @ Wheels
25 / 11 / 2007
