Author Topic: suspension  (Read 2206 times)
c33burgerman
suspension
« on: August 04, 2010, 11:16:46 PM »
i have a c33 laurel and am looking at adjustable suspension at the moment
i got told yesterday that p11 primera adjustables will go straight into my laurel.
i googled some pictures and they look similar/the same but can anyone confirm this?
as i'm not too keen to fork out for adjusties then find out they're the wrong set.
also are "platform" (brand) adjustables any good?
cheers
towbars... the gangster way to pull b*tches
http://www.zerofighter.co.nz
http://4doorwhores.wordpress.com
suspension
« Reply #1 on: August 04, 2010, 11:19:40 PM »
Cant say if they will fit or not, but surely the spring rates will not be right for your car!?
I could be wrong, but A31 Cef or Silvia suspension is similar to Laurel gear... maybe try looking in that area?
dimaat
suspension
« Reply #2 on: August 04, 2010, 11:35:24 PM »
S13 ones will definitely fit.  I havent heard of anyone using primera adjusties.  i'd be wary buying them tbh for that matter.  Being a fwd/4wd I doubt they would be compatible.
Also have never heard of platform?
c33burgerman
suspension
« Reply #3 on: August 05, 2010, 09:30:39 AM »
yea have run s13 ones it in before
oh yea true didit think about spring rate etc...
algood ill keep looking and saving up
should probably try stay away from second hand ones anyway...
smkadktz
suspension
« Reply #4 on: August 25, 2010, 11:34:44 AM »
yeah man would be best to stay away from 2nd hand adjusties cuz you never know what you'll get. never heard of primera going in to laurys either. a31 cefiro and s13 defintly fit. its all the same **** with a31s and c33s really. just a different shape shell. r32 fronts will fit in your rear to im pretty sure.
skidMark
suspension
« Reply #5 on: August 25, 2010, 01:18:08 PM »
a mate bought 2nd hands... put em in and they leaked and had to buy new ones to get cert... just go new, not worth the risk.
Every site needs a token bogan:
Quote from: gts-4r;541051
hit it with a hammer if it still doesn\'t work then its an electrical problem.
c33burgerman
suspension
« Reply #6 on: August 25, 2010, 03:20:00 PM »
yea ive learnt not to be cheap...
might take longer to get it done but if i go new parts it will be better in the long run
thanks for the help anyway
Zanthiath
    • http://www.dimension7.co.nz
suspension
« Reply #7 on: August 25, 2010, 06:09:53 PM »
Go for a set of s13 BC's
Best bang for buck,
pure methamphunmachine
c33burgerman
suspension
« Reply #8 on: August 26, 2010, 10:09:40 AM »
yea ive heard heaps of good things about BCs and including from people on here so will probably run with BC golds
saving time now...
smkadktz
suspension
« Reply #9 on: August 26, 2010, 01:51:47 PM »
bc's are pretty good. my mate uses them in his 20det cefiro. handles a dream! aparently when they have problems though theyre not easy to rebuild @ all.
c33burgerman
suspension
« Reply #10 on: August 26, 2010, 02:48:34 PM »
ah yea ive heard about different brands being a b***h to rebuild.
has he had problems with his?
im guessing if i get new ones theyll have some sort of warrenty and shouldnt give problems for a while anyway
sublime89
suspension
« Reply #11 on: August 27, 2010, 09:39:41 AM »
how do adjustables handle bumpy terrain, any loss in tracktion etc?
Redbush
suspension
« Reply #12 on: August 27, 2010, 10:58:06 AM »
spent some time airborne when had the dampners at their hardest with the s14
c33burgerman
suspension
« Reply #13 on: August 28, 2010, 11:06:20 AM »
hahah yea i went in a mates 180sx and the adjusties were on full (hard) damper
if he went round a corner too quick the back would just catch up
not bad but you could definatly feel it twitching!
bumps were a bit rough but aslong as you dont hit them too fast they are forgiving
but once again not the smoothest on corners
Redbush
suspension
« Reply #14 on: August 28, 2010, 11:15:53 AM »
14 clicks back of hard and they are mint for everyday driving
