Author Topic: suspension  (Read 2794 times)
smkadktz
suspension
« Reply #15 on: August 28, 2010, 03:05:41 PM »
he hasnt had any problems with his bc's that i know of. other then no cert at warrent time haha. theres a few that are gay to rebuild. teins are the easiest i got told by the mechanic in the company that rebuilds all our shocks and stuff.
c33burgerman
suspension
« Reply #16 on: September 03, 2010, 11:01:23 AM »
hahah sweet as ill keep it all in mind
BCs sound like a safe option
oh thats good to know about teins
ive heard that teins dont go very low?
not a huge issue rwally though cause theyre a good brand so should do the job well
towbars... the gangster way to pull b*tches
http://www.zerofighter.co.nz
http://4doorwhores.wordpress.com
4BOOSTN
suspension
« Reply #17 on: September 03, 2010, 12:43:58 PM »
depends whats type of tein you go for man, super streets- dnt go very low but have a very good ride quality,
tien flexs- go low and are more track orientated, heavier spring rates etc etc.
really comes down to what you want ae man.
most people arent to fussed with a harsher ride.
c33burgerman
suspension
« Reply #18 on: September 03, 2010, 02:26:38 PM »
oh true thanks man
yea im not worried about the bounce and rattles cause i have a daily so it doesnt have to be confortable.
roughly how much are tein flexs worth?
projects
suspension
« Reply #19 on: September 03, 2010, 03:24:51 PM »
i picked up some JIC FLT-A2's from a S13 and put them in my A31 cefiro. Yeah they were second hand but tidy condition no leaks and took the gamble on them. picked them up for $950 and pretty happy with them. dont some modifications to them so i could get my car nice and low in the rear as alot of suspension dont allow for much in the rear on nissans to go down. ended up with this height at the lowest in the rear and front could probably put the cross member on the ground if i wanted to...
Rb26det Holset S13 Track car.
c33burgerman
suspension
« Reply #20 on: September 03, 2010, 03:38:04 PM »
oh choice thanks for that
ive had JICs in the car before and they did go low however the ones i had were knocking a fair bit
ill keep an eye out for a set if they look really clean etc
in the process of saving for them at the moment so still a bit off
projects
suspension
« Reply #21 on: September 03, 2010, 03:50:23 PM »
yeah i got about another inch and half of lowness out of mine by rearranging the top hat-rose joint configuration. and also trimming off some of the thread in the lower joint bolt. worked a treat!!
c33burgerman
suspension
« Reply #22 on: September 03, 2010, 03:53:07 PM »
hahah thats a thought!
oh yea how do you re-arrange the top hat part?
does that just mount the top hat lower and therfore bring it down?
4BOOSTN
suspension
« Reply #23 on: September 06, 2010, 12:28:41 PM »
tein flexes new are around the $3000-3500......
projects
suspension
« Reply #24 on: September 06, 2010, 01:27:57 PM »
nah my top hat if i remember properly had the nut ontop, the rose jointed top hat, then a spacer and then the spring top hat and a spacer under that aswell.
so all i dont was pull it all apart rearrange it to top bolt, 2 spacers, top hat and coil hat. the rose joint didnt have full movement but enough to get into the mount and pivot more than enough to reach the lower hub mount.
So there was just more poking into the boot, the length from the top hat to lower joint bacame shorter. trimmed the bump stops a little. but its so stiff it will never get to them anyway. more just to please wof man on travel.
c33burgerman
suspension
« Reply #25 on: September 06, 2010, 04:57:03 PM »
Quote from: projects;508241
oh yup yup choice
sounds simple enough i guess
and by the looks of it they definatly went low!
projects
suspension
« Reply #26 on: September 06, 2010, 05:07:22 PM »
yeah very simple.
yeah had to raise it for mean time. but once i get some wider wheels to sit outside the guards and throw the car out on the track hopefully can get it sitting nice and low.
c33burgerman
suspension
« Reply #27 on: September 06, 2010, 05:12:12 PM »
Quote from: projects;508267
yeah very simple.
yea for sure!
with the wide body front and flaired back you'll be set!
