Author Topic: DIY: Spacers (Sick of that boaty factory look? - How spacers can help)  (Read 1030 times)
daxter
When I first got my R34 it had that boaty look.
After doing a lot of research an measuring, I bought 20mm spacers to go all-round, also making sure these are the correct spacers to pass the requirements for cert.
Step 1
Get your shiny new 20mm spacers
Step 2
Install spacers (I jammed the brake pedal on so I could tighten and torque up the spacers)
I also sprayed lots of WD40 on the bolts/nuts to help prevent corrosion.
Also before going ahead with this job I made sure I would be able to install the wheels without having to cut the factory bolts down a size, notice how the factory mags have lots of room for the bolts to stick out, this is good If I want to remove the spacers and go back to factory setup.
Step 3
Repeat for all wheels.
Before and after shots
Before
after
Before
after
More after shots
NSMO
« Reply #1 on: September 10, 2010, 12:58:53 PM »
+1 for everyone doing this... spacers/better offset/wider rims makes your liner look waaaay better!
skidMark
« Reply #2 on: September 10, 2010, 03:58:10 PM »
Boats don't have wheels...........
Mad fitment brah. heaps mad.
« Last Edit: September 10, 2010, 04:06:50 PM by skidMark »
Every site needs a token bogan:
Quote from: gts-4r;541051
hit it with a hammer if it still doesn\'t work then its an electrical problem.
lazy32coupe
« Reply #3 on: September 12, 2010, 10:36:07 AM »
boats dont have wheels LMFAO, but yea i got bought spacers for my front to clear breaks but made wheels fill guards a lot better needer save for rear spacers now :D
