Author Topic: r33 Coupe Build  (Read 63155 times)
dimaat
r33 Coupe Build
« Reply #15 on: January 17, 2011, 08:43:19 AM »
I agree with tube and fin, have run my HDI tube and fin on my car for 3 years now, good cooling and low pressure drop.  If you look on the inside of both, you shall see that the tube and fin looks less restricted.  And as above they are lighter than bar and plate.
r33 Coupe Build
« Reply #16 on: January 17, 2011, 11:39:36 AM »
Like said in link above, the real test of a intercooler is when car is pushed hard.
The coolant to air intercoolers seem to be the best in high hp applications. But they are said to be dragstrip use only.
Here's a boost graph from HDi showing a 1.4psi increase in boost level -
http://www.hybrid-power.com/GTSPEC%20INTERCOOLR/boost.jpg
Also at 23psi HDi GT intercooler with 600mmX300mmX78mm dimensions has a 0.5-1psi pressure drop (I assume with stock turbo?).
17rwkw (23rwhp) gain on a stock R33 with no changes to tune on ECU -
http://www.youtube.com/watch?v=Zf37Lq7sRW8&feature=player_embedded#!
« Last Edit: January 17, 2011, 03:01:59 PM by gtsr »
Ultimategtr
r33 Coupe Build
« Reply #17 on: January 17, 2011, 02:58:38 PM »
Interestingly enough, I run the GT Spec myself, but havent dyno'd mine for a few years.
SlaterRacingNZ
    • Slater Racing NZ
r33 Coupe Build
« Reply #18 on: January 17, 2011, 03:10:02 PM »
Good information guys, looks like I will be going with the tube and fin fmic. Will do the radiator at the same time due to previous owner running up the *** of a 4w4.
SlaterRacingNZ
    • Slater Racing NZ
r33 Coupe Build
« Reply #19 on: January 17, 2011, 04:56:46 PM »
Both On there way will have them in sometime this week.
« Last Edit: June 11, 2011, 01:48:11 AM by SlaterRacingNZ »
GETLOW
r33 Coupe Build
« Reply #20 on: January 17, 2011, 10:03:54 PM »
If your going to fit a surge tank you can keep your stock fuel pump. I would run a Bosch 044 external fuel pump as they flow alot more fuel then a walbro external fuel pump.
I'm not aware of anybody who sells front facing pleninum intercooler pipes.. You will most likly need to get them made, or get your new intercooler pipes modified to suit.
Shred Motorsport
67 Pharazyn Street
Lower Hutt, Wellington
(04) 569 7469
SlaterRacingNZ
    • Slater Racing NZ
r33 Coupe Build
« Reply #21 on: January 18, 2011, 12:08:18 PM »
One of the new toys is here, pity I have work now or I would put the bar in and take it for a alignment. Not to sure when the fmic will be here I hope this week sometime.
« Last Edit: June 16, 2011, 09:50:52 AM by SlaterRacingNZ »
NFMOUS_R33
r33 Coupe Build
« Reply #22 on: January 18, 2011, 12:10:50 PM »
cant go wrong with a fmic, full exhaust from turbo back, fuel pump, injectors, turbo and a ecu and tune :)
VTEC - Its like waiting for really really bad sex.
SlaterRacingNZ
    • Slater Racing NZ
r33 Coupe Build
« Reply #23 on: January 18, 2011, 12:56:32 PM »
Quote from: NFMOUS_R33;526069
Exactly what I had in mind lol will keep forum updated on what I'm up to.
RENEN
r33 Coupe Build
« Reply #24 on: January 18, 2011, 01:33:53 PM »
what brand fmic did you go with? and where did you get it from and for how much? bit off topic but does anyone know where i can get a bellmouth front pipe for a 33 like http://http://www.justjap.com/store/product.php?productid=18178&cat=276&page=1 in NZ? dont want one with seperate wg pipe
SlaterRacingNZ
    • Slater Racing NZ
r33 Coupe Build
« Reply #25 on: January 19, 2011, 02:15:27 PM »
Quote from: RENEN;526089
$399 FMIC Kit from Redline performance.
« Last Edit: March 22, 2011, 08:29:23 PM by SlaterRacingNZ »
SlaterRacingNZ
    • Slater Racing NZ
r33 Coupe Build
« Reply #26 on: January 19, 2011, 02:18:14 PM »
Progress on the car.
The hicas lock bar is in, going for a alignment tomorrow at 9am. Took me a good hour and a half to get the rack off the tie rod ends were a bitch to crack off. Will throw a picture up tonight when I get home. I can already notice a massive difference in not having the hicas system a lot more predictable/fun.
SlaterRacingNZ
    • Slater Racing NZ
r33 Coupe Build
« Reply #27 on: January 20, 2011, 11:40:36 AM »
FMIC has arrived so we'll see if there is enough time this weekend to put it in or test fit it. Replaced the rear brake pads today as old ones were looking a bit abused, also put some anti squeal padding on the front brake pads which seem to have done the trick.
As I promised would put a picture of the assembled lock bar.
« Last Edit: July 31, 2013, 08:52:35 AM by SlaterRacingNZ »
deepdarkminimal
  • www.nzprojectcars.com
    • NZ Project Cars
r33 Coupe Build
« Reply #28 on: January 20, 2011, 12:06:35 PM »
nice progress.
where did you get that lock bar from and how much if you dont mind?
was it pretty straight foward to chuck it in?
NZ's newest dedicated project car forum
samos69
r33 Coupe Build
« Reply #29 on: January 20, 2011, 01:08:07 PM »
Just a tip - changing to a lock bar can be considered a suspension modification in need of certification so depending on who does your warrants they make ask for a cert.
Mine was painted black when I got it and I've never had any issues, even through VTNZ as it looks factory.
Sam
Beginning build phase S1DWYZ MkII in progress.
