Author Topic: HR30 mixture adjustment  (Read 1364 times)
AGRORB
« on: May 06, 2011, 09:04:41 PM »
I'm told that you can make small changes to AFR on EFI L series engines by adjusting a screw on the AFM, is this true? If so, where is the screw located? Want to lean mine out a little as its fair belching out black smoke under load.
Quote from: ibb&;559471
Quote from: nathan1017;591767
giving the knob to sdu.
StageFumer11
« Reply #1 on: May 06, 2011, 10:15:26 PM »
rightyo.. That screw is for idle adjustment only.
You can adjust the tension on the AFM flap. Take offthe black cover. Mark where the locking tab is on the dial. Tighten the adjustment by turning the coged wheel.
Go 4-5 clicks only at a time, This will lean out the mixtures. You might find it has a ET afm fitted and its the wrong setting. Usually tho with the l20et, 3500-4000rpm onwards the afm is fully open and on a pre map.
1985 R30 Skyline Coupe
StageFumer11
« Reply #2 on: May 06, 2011, 10:23:44 PM »
AGRORB
« Reply #3 on: May 07, 2011, 01:20:44 PM »
I have noticed the car sounds different and picks up a lot more around 3500-4000rpm... hmmm...
StageFumer11
« Reply #4 on: May 07, 2011, 01:56:16 PM »
Yup, afm flap will be fully open. Causing it to go onto the programed map.
So tighten that adjustment to tweak the low end fueling.
I did it on the l20et quite well. Had 270cc injectors, ran 24-28deg timing etc.
Got some good low down torque on that also.
AGRORB
« Reply #5 on: May 07, 2011, 02:08:09 PM »
Any idea where stock timing should be on L20E? Wouldn't mind giving everything a tickle up at once.
StageFumer11
« Reply #6 on: May 07, 2011, 03:40:40 PM »
10btc was turbo, i think the N/A's were 20btc
