Author Topic: SDU Dyno Day 30/7/11  (Read 19946 times)
Stalk3r
« Reply #165 on: August 02, 2011, 01:55:14 PM »
nah it wouldnt hold anything, and when it would it wouldnt shift where he wanted etc, snow mode just makes it start in 2nd instead of first, power holds it longer, the other thing thats a significant factor in the problems is, when i did the conversion the cima has around 7 different computers under the dash, i removed a bunch of em (traction control etc), so we were thinking it may be throwing a bit of a wobbly about that, its shiftings all over the place really but doesnt bother me, me and the woman have gotten used to its idiosyncrasies etc
ibb&
« Reply #166 on: August 02, 2011, 01:58:09 PM »
191kw is still bawse as **** for a daily!
SDU DERAIL CREW WHAT!
Garage Stalk3r official cleaning lady
b00stinz
« Reply #167 on: August 02, 2011, 02:11:21 PM »
You should have seen Aarons face when I said 190kw. Cracked me up.
Stalk3r
« Reply #168 on: August 02, 2011, 02:13:31 PM »
i actually thought youd said 90 and you were just being a dick, id be pissed at doing a vh conversion to gain 20kw
b00stinz
« Reply #169 on: August 02, 2011, 02:16:44 PM »
Yeah I did say 90kw first haha
ibb&
« Reply #170 on: August 02, 2011, 02:27:17 PM »
Ahahahaha all hail glorius maximus
b00stinz
« Reply #171 on: August 02, 2011, 02:32:30 PM »
Gllloooooorrriiiooooussssss maaaaaxxxiiiiiimmuuuusssss
SafT
« Reply #172 on: August 02, 2011, 03:06:50 PM »
So if hold/snow mode makes it start in second, and having the lever In 2 means it won't go above second which other gears will it select?
Stalk3r
« Reply #173 on: August 02, 2011, 04:28:40 PM »
from memory having it in 2 it will just ignore and go to 3 if you take it all the way out to r-line
« Reply #174 on: August 02, 2011, 06:16:50 PM »
No putting Stageas on the dyno we select 2 and put the snow button on and it stays in 2 - doesn't kick down to 1 or change up.
Stalk3r
« Reply #175 on: August 02, 2011, 06:46:24 PM »
so as i said earlier, chances are the auto ecu is having a hernia over the fact that ive dicked with its surrounding ecus
SafT
« Reply #176 on: August 02, 2011, 08:09:51 PM »
Stalk3r
« Reply #177 on: August 02, 2011, 08:26:40 PM »
ZOMG i<3u
i was pondering today whether something existed, even to the point where i was pondering a hideous american ratchet shifter
SkylineObsession
« Reply #178 on: August 04, 2011, 12:03:43 PM »
Quote from: xdrift;561244
I'm in Dunedin now, going to uni
O RLY?
http://www.skylinesdownunder.com/forums/showthread.php?t=63551 ;)
