Author Topic: R31 wagon.  (Read 4103 times)
TB48DET
R31 wagon.
« on: August 16, 2011, 06:16:06 PM »
Had this wagon for a few months
Hoping someone on here could answer a few questions
I need to lower it 110mm but that leaves me with 70mm shock travel
Can i buy shorter inserts? where from?
Will be able to cut the weld out of the hub and shorten the body for them to fit
this is how it should look
AGRORB
R31 wagon.
« Reply #1 on: August 23, 2011, 08:40:06 PM »
Off topic, but ****, what are those wheels?! I want them :D
Quote from: ibb&;559471
Quote from: nathan1017;591767
giving the knob to sdu.
TB48DET
R31 wagon.
« Reply #2 on: September 06, 2011, 01:06:54 PM »
I got them for free a few years ago called mangels
TB48DET
R31 wagon.
« Reply #3 on: September 06, 2011, 01:08:42 PM »
RB30DET-R30
R31 wagon.
« Reply #4 on: September 06, 2011, 04:02:58 PM »
You can get similar ones brand new off trademe for under $400 for a set of 15x8 and you can also get 15x10's for just under $500. But you can only really use them on 4 stud and you need to purchase 4 to 6 stud adaptors but you can get them in 5x114.3 but they cost lots more I think!
Ethan
R31 wagon.
« Reply #5 on: September 06, 2011, 05:52:51 PM »
mangel modulars? common on rotarys arent they? with Eager tyres?
RB30DET-R30
R31 wagon.
« Reply #6 on: September 07, 2011, 01:53:44 AM »
Mangels is a brand like ROH or Work, the Modulars where a type of wheel & had circle holes and these type are called Wellers I think.
Arro
    • http://www.club-s12.org
R31 wagon.
« Reply #7 on: September 27, 2011, 08:42:11 PM »
Those look like (what here in the US are) common stamped steel wheels... there are places here that can make you a wheel in whatever diameter and offset and bolt pattern you want, for about $50-80 USD a piece... offered in white, black, black with a little red pinstripe on the lip, and of course, chrome.
Cheap way to get a wheel in whatever spec you want, but steel wheels are HEAVY.
-Jason Arro, Club-S12.org Site Administrator
Club-S12: International Community for the 1984-88 Nissan Silvia, Gazelle, and 200SX
1985 Nissan Silvia RS-X FJ20
1985 Nissan 200SX KA24DE
live4liners
R31 wagon.
« Reply #8 on: September 27, 2011, 08:49:50 PM »
if your only problem is non captive springs, there are probably shorter shocks out there.
TB48DET
R31 wagon.
« Reply #9 on: October 26, 2011, 01:00:54 PM »
Sorted it with S13 front suspension and made coil overs to fit them that drop the whole shock and spring down so it wont come uncaptive
Still used a 65mm spring
In the rear i still need to sort shocks but will prob shorten standard
projects
R31 wagon.
« Reply #10 on: October 26, 2011, 01:22:34 PM »
quick fix in the rears are a R32 front shock with the rear top hat changed over to suit and maybe trim a coil out. I'm guessing the wagon set up is the same as the sedan that is..... thats all my mate done with his R31.
Rb26det Holset S13 Track car.
TB48DET
R31 wagon.
« Reply #11 on: October 27, 2011, 04:24:25 PM »
It has a flat diff like a VL commy.. I just cut the spring mounts off  the diff and made new ones to suit coil over springs. Got heaps of them at different lengths and weights so have sets for track or street
tronske
R31 wagon.
« Reply #12 on: November 21, 2011, 05:32:50 PM »
damn i like your wagon!! can't wait for the finish project
