Author Topic: RB Injector Size and Resistor Info  (Read 15752 times)
Stalk3r
« Reply #15 on: September 27, 2011, 09:51:00 AM »
well no, if the "full voltage" side of the relay is a fused direct link to the battery when its on that contact it will see 13.8, its the low voltage side that i was addressing above
Pandaemonaeon
« Reply #16 on: September 27, 2011, 10:00:11 AM »
Hmmm. It appears that the lack of voltage is more to do with the rubbish factory wiring then, as you will never see charge voltage at the pump with the factory wiring.
pure methamphatamachine
Stalk3r
« Reply #17 on: September 27, 2011, 10:05:32 AM »
well thats to be expected, it'd be through about 10m of old oxidised wiring, also remember every plug and or join in the line is a resistance based voltage drop that will inevitably rise with age
jazz
« Reply #18 on: October 14, 2011, 08:40:02 PM »
Ok, does anyone know how to decipher the stamped numbers on injectors, going from the connetor colours and impedance i may have a set of gtr injectors in my r32 gtst. The Table and info above also seems to give the Nissan SKU numbers.
Stalk3r
« Reply #19 on: October 14, 2011, 11:54:51 PM »
can you give me/us the numbers, ill see what i can do for you
jazz
« Reply #20 on: October 15, 2011, 08:54:17 AM »
The numbers ive got are
A46-000001 5L31-9912 red top, im 99% sure these are factory rb20det. Impedance 14 Ohms
the other injectors ive got are
A46- 00 0A52-9617D Yellow Top, the ones i need to confirm. Impedance is 2.1 Ohms
GQDZLA
fitting high imp injectors on a GTR???
« Reply #21 on: February 12, 2012, 08:52:18 PM »
ok so I got some cheep high imp injectors, if I want to fit them to a GTR I then remove the factory resistor pack and some how "loop" it back into the plug so it gets soginal but no extra resistance added? anyone done it?
[SIGPIC][/SIGPIC]R33 GTR that got some serious upgrades and more to come!! 1998 Autech 260RS Stagea, 96 R33 GTS-4
