Author Topic: walbro 500hp fuel pump  (Read 2199 times)
hacksaw
    • http://www.facebook.com/profile.php?id=663316138
« on: September 09, 2011, 12:19:01 PM »
do i need to set up an aftermarket fuel pres reg if i install my walbro 500hp fuel pump or do anything else for that matter?
1990 Nissan Skyline R32 GTS-t - Track Hack
Sh*t happens, deal with it
Neal
« Reply #1 on: September 09, 2011, 12:21:35 PM »
Nah. Just jam it in.
The factory fpr will do the rest.
frost.motorsport
    • http://www.frostmotorsport.co.nz
« Reply #2 on: September 09, 2011, 12:24:20 PM »
what would be useful is to check your fuel pressure @ the rail while on the Dyno, as it may be worth an adjustable if your tuner deems that more/less fuel pressure would help.
I wouldn\'t have road rage if morons didn\'t have drivers licences!
https://www.facebook.com/FrostMotorsport
hacksaw
« Reply #3 on: September 09, 2011, 12:35:01 PM »
Quote from: Neal;569592
wicked!
Quote from: frost.motorsport;569594
agreed. tune would def help. lacking in $$ at the moment :boohoo:
« Reply #4 on: September 09, 2011, 03:37:46 PM »
Directly wire it for full battery voltage while you are installing it - cost of a relay and some heavy wire - well worth iot for later.
mlracing.co.nz
« Reply #5 on: September 09, 2011, 03:41:00 PM »
Not required but handy and probably required for down the line sometime ;D
After performance parts for your car? PM Me, email sales@mlracing.co.nz or visit www.mlracing.co.nz!
R32ONP
« Reply #6 on: September 09, 2011, 10:27:15 PM »
pressure will slightly rise with a walbro pump on a stock reg..
Steer from the rear ..... Drop it like its hot !!!
Shrike
« Reply #7 on: September 09, 2011, 10:43:14 PM »
my 550hp fuel pump with tomei fuel fpr = 75psi at cranking :P
Quote from: MZ ROLA;555218
Personally i prefer DP
Quote from: Stalk3r;558679
mmmm sausage
hacksaw
« Reply #8 on: September 10, 2011, 01:10:56 PM »
so will it damage anything if i dont adjust the fuel pressure?
mitchell_r32coupe
  • RB20DE
« Reply #9 on: September 10, 2011, 06:06:57 PM »
No it will be fine, some friends have made 200kw without changing fpr from factory with no pressure issues. I believe factory fpr is rising rate, but you cant adjust it.
R32ONP
« Reply #10 on: September 10, 2011, 06:22:53 PM »
yeah stock does rise 1:1  with boost...
how do most people on here join their wires?
base
« Reply #11 on: September 10, 2011, 06:31:28 PM »
solder and heat srink
R32ONP
« Reply #12 on: September 10, 2011, 06:36:15 PM »
heat shrink all good sitting in fuel all the time?
R32ONP
« Reply #13 on: September 10, 2011, 06:38:26 PM »
anyone know if the joining blocks are fine inside the tank?
gts-4r
« Reply #14 on: September 10, 2011, 06:40:32 PM »
i would use butt splices then heat shrink over them. that's whats in the walbro install guide
