Author Topic: Ryeoons R32  (Read 78756 times)
30ed32
Ryeoons R32
« Reply #15 on: April 05, 2012, 08:34:13 PM »
Quote from: ryeoon;596453
So you take the door skin off?
nah, you can get it out through the electric window switch hole
Edit: that was a joke.  Yes
lol everything I say is just made up, don\'t pay any attention
Ryeoon
Ryeoons R32
« Reply #16 on: April 05, 2012, 08:36:36 PM »
Quote from: 30ed32;596454
Ha, lucky you told me this. I planned on trying to get it out by unbolting it then trying to get it out through one of the holes. Had to do that for a ****ty Honda I had.
Edit: Okay wait, I think I confused myself. Were you guys talking about the door card? Cause of course that had to come off.
« Last Edit: April 05, 2012, 08:38:23 PM by ryeoon »
30ed32
Ryeoons R32
« Reply #17 on: April 05, 2012, 08:38:01 PM »
An entire window regulator out with the skin on and out a hole... interesting
Stalk3r
Ryeoons R32
« Reply #18 on: April 05, 2012, 08:41:29 PM »
Hahha, yes without a doubt, how were you inspecting it without taking the door skin off?
Forgive my possible vagueness but I'm in a car on cellphone internet without an r32 in front of meso ill try step u thru it.
Open the door, pull the internal handle as if you're trying to open the door, prise the backing plate out from behind the handle (its clipped to the skin) after that take the little cellphone holder/handle bit out (there's a screw in the bottom of it) then lift the front of the window switch assembly, it should pop out front first, when out of the skin unplug it and put to the side, then there's 3 or 4 screws along the bottom of the skin from memory take the out then grab the bottom back corner or the skin and squeeze you hand between it and the door, doing that alone should pop a few of the clips the proceed up and pop the remaining one o 2 the go back to the bottom and move towards the front of the door to pop the rest, there's a screw at the top front that needs to be removed also, covoered by a plastic dome once all that's done pull the skin out a bit from the bottom and slide up should come off easily window up or down no matter bit easier with down tho
 Regulator is the little black box mounted to the door towards the bacl with 6 (from memory, could be 8) wires and a white and yellow plug
All of this is from memory so could be off a little but I don't think so
Ryeoon
Ryeoons R32
« Reply #19 on: April 05, 2012, 08:45:56 PM »
Hahahaha, Yeah that's easy. And relatively correct. But the window reg sits like behind the inside of the the door frame. That's what I'm talking about. I'll take a picture to help ease the confusion.
Bare with me a couple min.
Stalk3r
Ryeoons R32
« Reply #20 on: April 05, 2012, 08:56:06 PM »
I'm waiting with baited breath
Ryeoon
Ryeoons R32
« Reply #21 on: April 05, 2012, 08:57:39 PM »
At this point now. It's right behind that centre part where handle type part is. You can see the piece of wood holding the window up. So how do I get it out from there?
Stalk3r
Ryeoons R32
« Reply #22 on: April 05, 2012, 09:05:21 PM »
Lolmax, derp etc :)
What you're talking about is not the regulator, you're talking about the motor and its mechanism, the regulator is the little black box exactly where I said it would be
And yes you take the motor out one of the holes
Ryeoon
Ryeoons R32
« Reply #23 on: April 05, 2012, 09:11:28 PM »
Ahhh crap. I'm so used to calling the whole thing a regulator. So I bought the wrong part. Anyone got a spare drivers window motor they wanna sell?
30ed32
Ryeoons R32
« Reply #24 on: April 05, 2012, 09:24:29 PM »
just slap some new brushes in it
Ryeoon
Ryeoons R32
« Reply #25 on: April 05, 2012, 09:28:54 PM »
Quote from: 30ed32;596463
I'm not too familiar with window electrics. I'll probably still just replace the whole motor but if you want to explain to change my mind, feel free.
Ryeoon
Ryeoons R32
« Reply #26 on: April 05, 2012, 09:33:02 PM »
Oh, also urgently after a left rear outer tie rod and left hand engine mount for WOF.
Stalk3r
Ryeoons R32
« Reply #27 on: April 05, 2012, 09:39:35 PM »
If u haven't sorted by Monday let me know I have both
30ed32
Ryeoons R32
« Reply #28 on: April 05, 2012, 09:53:38 PM »
Quote from: ryeoon;596464
Probably eaiser to buy a new second hand one than to do the brushes if it is the brushes that are at fault.
Ryeoon
Ryeoons R32
« Reply #29 on: April 05, 2012, 09:55:40 PM »
It's the wire cords. They've been chewed up and pulled out of wherever they're meant to be. Yeah, stuff it. I'll buy a new window motor.
