Author Topic: Ryeoons R32  (Read 71384 times)
Ryeoon
Ryeoons R32
« Reply #30 on: April 06, 2012, 10:01:54 AM »
Sourced a new wing mirror and window motor today. Also brand new vertex body kit.
« Last Edit: April 06, 2012, 10:06:10 AM by ryeoon »
Ryeoon
Ryeoons R32
« Reply #31 on: April 06, 2012, 07:19:47 PM »
« Last Edit: February 08, 2013, 02:02:48 AM by ryeoon »
GTS4R
Ryeoons R32
« Reply #32 on: April 06, 2012, 07:27:43 PM »
Dry ice from BOC gas, then when you are done you can blow some coke bottles up, If its a road car with a little track time I would just leave it there with the carpet.
30ed32
Ryeoons R32
« Reply #33 on: April 06, 2012, 09:38:57 PM »
I wouldn't touch the sound deadening I don't know what the big obsession with it is.
lol everything I say is just made up, don\'t pay any attention
Ryeoon
Ryeoons R32
« Reply #34 on: April 06, 2012, 10:50:52 PM »
Yeah, I got rid of all the matting anyway (15kg of it later) so I'll leave it at that. Put everything back in and cleaned it up nicely. Almost got roped in to taking the whole dash out just so I could get that whole carpet up but stopped when I got to removing dash cluster. Got the A/C working which was a bonus too. Won't get anything done tomorrow cause I'll be off to Hampton Downs for the drifting.
« Last Edit: April 06, 2012, 10:59:14 PM by ryeoon »
Ryeoon
Ryeoons R32
« Reply #35 on: April 09, 2012, 10:54:04 AM »
New spark plugs put in. I went with Bosch platinum plugs, seemed almost too cheap at supercheap (43$) for a set of six. The old ones I took out were NGK iridiums so I considered just cleaning them up as I hear they are quite good but decided to replace anyway as a few were quite cooked. What a difference it made! Much better response. Also learnt that my engine has a wasted spark set up.
Unfortunately I spilled a bit of battery acid on my back seat as a bat flipped over without me noticing. So I pulled the back seat out and spent a lot of time absorbing it up with an old towel and then watering it down with a hose. I heard you use Baking soda so I chucked that on too (With out inhaling the fizzy vapor) and it seems to have cleaned up without any holes.
Will be doing a radiator flush and general engine clean up today.
« Last Edit: April 09, 2012, 11:02:04 AM by ryeoon »
Ryeoon
Ryeoons R32
« Reply #36 on: April 11, 2012, 11:41:02 AM »
Arrrrghhh. Struck my first problem. Started cleaning up engine bay today. Started out by draining the radiator which was straight brown. Flushed the hose through it til it turned clear. Cleaned out reservoir which was also brown sludge and then once I had washed the brown crap out of everything I filled up the rad with water, just to take it for a quick drive to get it all through. It started up fine and took off as normal. After a few roads of driving the power started dying off a little. The gears were being a bit funny so I pulled over and checked under the car, nothing was leaking. The car was almost stalling just while idleing. Hopped back in and turned around. Car had minimal power, had to floor it in every gear just to get a bit of a rev. Luckily made it home in 2nd gear. Jumped out, looked under bonnet, top hose and bottom hose both hot. After a bit of abnormal idleing it stalled. Will let it cool down and then I'll re-check all the rad stuff. Anything I'm missing?
Edit: Once it cooled down, the water was back to brown gunk, so I flushed it yet again. Took it up and back the road and seemed okay again.
« Last Edit: April 11, 2012, 12:20:25 PM by ryeoon »
30ed32
Ryeoons R32
« Reply #37 on: April 11, 2012, 12:24:39 PM »
good idea to flush the rad both ways and the whole system with the car running and heater on.
Ryeoon
Ryeoons R32
« Reply #38 on: April 13, 2012, 11:24:38 AM »
Replaced wing mirror and preparing to replace drivers window motor. Should take me a whole day...
zifzone
Ryeoons R32
« Reply #39 on: April 13, 2012, 04:39:28 PM »
Nice to see you got a coupe man.
ID1000\'s / FMIC / PLENUM / MP.TURBO!
Ryeoon
Ryeoons R32
« Reply #40 on: April 14, 2012, 07:20:19 PM »
Thanks. Here's the new vertex body kit I scored for $300. Needs a little modification but still cheap. You can see a crack in the front bumper. Won't put on car until next week though. Still after a engine mount and tie rod. Also didn't bother trying to change window motor yet.
Ryeoon
Ryeoons R32
« Reply #41 on: April 14, 2012, 07:24:51 PM »
Also getting $400 for my rims when I want so I will be looking for some that are similar to these bad boys
http://4.bp.blogspot.com/-HwnEntTT3E0/Tf6aqf6W4-I/AAAAAAAAEcY/YAuouDyP7fU/s400/R32GTR1.jpg
mlracing.co.nz
Ryeoons R32
« Reply #42 on: April 15, 2012, 12:15:44 AM »
Quote from: ryeoon;596740
Those are AVS Model 6, just incase you want to look for some :)
After performance parts for your car? PM Me, email sales@mlracing.co.nz or visit www.mlracing.co.nz!
Ryeoon
Ryeoons R32
« Reply #43 on: April 15, 2012, 03:41:58 PM »
Quote from: mlracing.co.nz;596754
Thanks heaps for that! I was going to ask if anyone knew what they were. They seem rather rare.
« Last Edit: April 15, 2012, 03:51:17 PM by ryeoon »
Ryeoon
Ryeoons R32
« Reply #44 on: April 15, 2012, 08:35:56 PM »
So good to have driver window working! Means I can go back through maccas drive through =)
Bought a radiator flush and spent ages flushing radiator. Stupid how long it took the hose running through the engine for the water to stop coming out brown. Filled back up with coolant now. Next up is oil change which I bought a engine flush and two 4L bottles of magnatec for. Also will put on the new Nismo oil filter at same time.
