Author Topic: Ryeoons R32  (Read 67833 times)
4ever_sideways
Ryeoons R32
« Reply #315 on: May 12, 2013, 05:04:11 PM »
I think you'll find yourself having to get the hardrace ones (or similar). I've had those camber arms on for yonks. I've never been questioned at wof time about my arms considering they aren't certed. Guess they just saw the plate and assumed they were listed.
« Last Edit: May 12, 2013, 05:06:12 PM by 4ever_sideways »
Nothing is fool proof to a well accomplished fool.
Quote
Some people are like clouds, once they f*ck off it\'s a beautiful day.
Ryeoon
Ryeoons R32
« Reply #316 on: May 12, 2013, 05:16:42 PM »
Does r33 arms fit r32? Questioned for these -http://www.trademe.co.nz/motors/car-parts-accessories/nissan/suspension/auction-591129277.htm
They're cheap and as said above are certifiable.
Also sent autolign an email for pricing on 30mm & 28mm nolathane sway bushes for my aftermarket sway bars.
« Last Edit: May 12, 2013, 05:28:53 PM by ryeoon »
sk8seddon
Ryeoons R32
« Reply #317 on: May 12, 2013, 06:16:56 PM »
those you put the link up for have bushes on the ends and should be ok, just rose joints are considered to rough for public roads
Ryeoon
Ryeoons R32
« Reply #318 on: May 12, 2013, 06:37:03 PM »
Quote from: sk8seddon;614971
But will they fit? Not sure of any compatibility between different models. They don't seem to stock any stated 32 ones.
sk8seddon
Ryeoons R32
« Reply #319 on: May 12, 2013, 07:49:49 PM »
prity sure rear toe arms are the same between r32 subframes and r33 subframes. so long as you have a non hicas subframe.
Ryeoons R32
« Reply #320 on: May 12, 2013, 07:55:29 PM »
pretty sure toe arm bush  size is bigger.. 10mm wider on r33 or something like that
sk8seddon
Ryeoons R32
« Reply #321 on: May 12, 2013, 08:02:51 PM »
true i did use 10mm of washers to take up the gap on mine...
Ryeoons R32
« Reply #322 on: May 12, 2013, 08:18:52 PM »
he wants to do it the other way around though
« Last Edit: May 12, 2013, 08:21:52 PM by 30ed32 »
Ryeoon
Ryeoons R32
« Reply #323 on: May 12, 2013, 08:24:01 PM »
Bugger, can't use them then.
Ryeoon
Ryeoons R32
« Reply #324 on: May 14, 2013, 10:32:56 AM »
I got the set that comes with the traction rods. If I have to change later then it's easy enough.
Ryeoon
Ryeoons R32
« Reply #325 on: May 19, 2013, 11:35:27 AM »
New rear window lip, will be attached once painted & windows tinted next w/e. Here's my hicas line remedy til it buggers the pump. Need to make the curve in hose better. Took me a few hours by myself.
4ever_sideways
Ryeoons R32
« Reply #326 on: May 19, 2013, 11:58:40 AM »
You may as well trace those hicas lines to the front and loop them there. Gets rid of that piping then.
Quote
gtsr
Ryeoons R32
« Reply #327 on: May 19, 2013, 01:08:49 PM »
That loss in internal size of hose (where it kinks) is going to cause a flow restriction thus rise in pressure. The next place it leaks probably will be at the resouvoir hoses, hoses next to / just behind battery.
You can cut the rubber hoses x2 that go from the block piece near rear wheels to the hardpiping which goes to HICAS rack and join the 2x rubber hoses together to loop it near rear wheels.
Ryeoon
Ryeoons R32
« Reply #328 on: May 19, 2013, 06:23:05 PM »
Just a matter of being able to cut the pipe. I used a proper pipe cutter which was hard with the lines so close together. I imagine I'll just remove lines altogether when I get around to putting a non hicas pump on. I intend on having no kink in that hose.
Ryeoon
Ryeoons R32
« Reply #329 on: May 25, 2013, 08:56:06 PM »
Slack w/e for me! Only got a few hours work in on the skyline. Realised II need a 36mm socket to get the axles out of the hubs =/
