Author Topic: Ryeoons R32  (Read 81720 times)
Ryeoon
Ryeoons R32
« Reply #915 on: May 02, 2014, 05:27:33 PM »
Andy at xtune still mucking me around so I went in to E&H today and had a chat. Deciding to go with link as I have enquired to most tuners in Auckland i.e Hitech, ST Hitec, E&H etc & they all think a Link is by far the best option. If things don't work out well, I still have the Link ECU & accessories which is the majority of the cost.
E&H are also amazing to deal with & having them 15 min away from me is ideal.
Wanting to go with the stand alone & trying to find ECU to factory rb loom adapter harness but I don't think they're around anymore. So might just have to go wire in.
They reckon I will be able to get tuned not next week, but the one after.
Looney_Head
Ryeoons R32
« Reply #916 on: May 03, 2014, 05:38:48 PM »
i still have a G1 link... just saying hehe.
are you not going to go for a G4 GSTLink?
god is just an imaginery friend for grown ups
Ryeoon
Ryeoons R32
« Reply #917 on: May 04, 2014, 12:01:45 AM »
You talking about the plug in? Nah, want one I can use for whatever I desire haha
Looney_Head
Ryeoons R32
« Reply #918 on: May 04, 2014, 05:14:21 PM »
yeah was talking about a plug in, and fair enough, grand plans later down the line? as Downtrail said have a look into a Megasquirt MS3-pro, excellent value for money and a powerful ecu.
Ryeoon
Ryeoons R32
« Reply #919 on: May 07, 2014, 05:39:54 PM »
Boom. G4 storm on it's way to me tomorrow. Saved $400 already. Gonna find adapter to rb harness or get one made now & start installing to save my self a further $850+gst from E&H.
Ryeoon
Ryeoons R32
« Reply #920 on: May 16, 2014, 06:26:36 PM »
Have been slack on the updates but car is currently at E&H! Downtrail has made me a fantastic Link to loom adapter harness however having 2 issues with it which I need to sort out. One is that the ECCS relay is not being activated by the LINK & also once the ignition is turned on, the fuel pump comes on but when car is turned off, the fuel pump stays running. Once these 2 things are fixed E&H say there is no reason why it shouldn't fire up with the base tune they have put on the LINK. Told them to put work on hold as they're wanting to charge me $400+ to fix these 2 issues!!!!!!!!!
 Problems go away when I plug a factory 25DE ecu in to move the car around.
Filled it up today with 98 pump gas today for it to be tuned on & also they're gonna tune to 14 psi with a 7k rpm limit.
« Last Edit: May 16, 2014, 06:28:56 PM by ryeoon »
Ryeoon
Ryeoons R32
« Reply #921 on: May 21, 2014, 05:53:48 PM »
Went & seen my skyline at E&H today after dealing with some problems with it over the past few days. Good to see it running today on the new Link G4. I went there to pull fuel rail off to find out why fuel was leaking to save me some coin from them doing it & one of the new o rings that came with the DW injectors was split which I've read is all too common with new DW o rings on there injectors. Tomorrow they're gonna start the dyno preparations i.e Boost leak check etc then hopefully they'll start the Dyno tuning in the afternoon.
benji-nz
Ryeoons R32
« Reply #922 on: May 21, 2014, 06:14:24 PM »
Finally!
"I ran a 25 turbo on my 20 when I had stock cams. Managed 300whp at 24psi on e85 figured that was the max on that turbo"
b00stinz
Ryeoons R32
« Reply #923 on: May 21, 2014, 07:33:30 PM »
So what was the issue with the Link not turning the fuel pump off and ECCS relay?
Almost light at the end of the tunnel though!
What a mission you've been through man, I would be about ready to punch a baby by now.
Ryeoon
Ryeoons R32
« Reply #924 on: May 21, 2014, 09:10:48 PM »
Quote from: b00stinz;626035
They didn't set the fuel pump settings up right on the Link but that's sweet now. Apparently Links are also not able to trigger the ECCS relay properly & require another relay wired in which is what E&H have done but Downtrail tells me he could have set it up to run off a Aux from the Link which would have saved me some coin from E&H as they know I'm on a strict budget. To stick to the budget they've knocked out me getting a boost dial & installation but I'm not fussed because I'd rather have with boost permanently set.
I'm not quite excited yet though as I know they'll be in contact with me tomorrow when they start having dyno issues...............
Gotta pay off there new 4x4 buggy thing somehow.....
« Last Edit: May 21, 2014, 09:11:50 PM by ryeoon »
Ryeoon
Ryeoons R32
« Reply #925 on: May 22, 2014, 08:00:26 PM »
Lucky I didn't get excited. Intake manifold cracked one of the runners on pressure testing at E&H. I went in today after work as I was looking at taking car home to pull it all out again but decided to try knead it up. They're gonna try pressure test it in again in the morning & go from there. I asked them how much pressure they put in it & they said they pressure test at 20 psi for 14psi applications.
See how we go tomorrow I guess.
gtsr
Ryeoons R32
« Reply #926 on: May 22, 2014, 08:01:52 PM »
Quote from: ryeoon;626033
Most people use the stock O rings with the DW injectors.
« Last Edit: May 22, 2014, 08:04:08 PM by gtsr »
benji-nz
Ryeoons R32
« Reply #927 on: May 22, 2014, 10:01:51 PM »
That must be very frustrating there dude. You cant win with the manifold, or the skyline for  that matter! At least it is the home stretch and you'll get there soon
Looney_Head
Ryeoons R32
« Reply #928 on: May 23, 2014, 07:51:24 AM »
damn man thats rough about the manifold :( hope you get it sorted and get to enjoy the car soon.
Ryeoons R32
« Reply #929 on: May 23, 2014, 12:27:32 PM »
crack at 20psi that doesnt sound right
