Author Topic: Removing Roof Rack from S1 & S2 Stagea's  (Read 2821 times)
Bender
« on: June 25, 2012, 05:48:11 PM »
Tools needed are
    •Small flat head screw driver
    •Phillips screw driver
    •12mm long(tube) socket (preferrably 1/4 inch drive)
    •14mm spanner
    •1/4 inch drive rachet & extensions
    •Gentle hands always good.
Frist remove the side tirms from back to front, remove the rear hood lining and you might able to get away from letting the front part just hanging down to get front nuts but if you have a sunroof, It be easyer to take the whole lot out as you have bracket remove before you get to the nut the for roof. racks. Is a total of 10 nuts to be undone, Only need a tube socket for the 4 at the rear.
Once all the nuts undone, The rails should just pull off, They may need little assistance as the have been on there a long time. Once the rails are off, You will have total of 10 hole and also 6 rectangular holes in the panels which will need to be filled.
Front
Without sunroof
With sunroof
Middle
Rear
I will update once I have finish mine and how i full up the holes.
FiShYmAn
    • http://www.primowireless.co.nz
« Reply #1 on: July 13, 2012, 04:09:52 PM »
someone was selling some inserts for stags, you remove the rails and bolt in some flat inserts, it looked really good.
looking forward to seeing your end result :)
Skylines Downunder Forums sponsored and hosted by:
Bender
« Reply #2 on: July 13, 2012, 05:31:38 PM »
Do you know who that was?
I have done a other thread since I done this one as this only been posted up today i think
Here the other one
http://www.skylinesdownunder.com/forums/showthread.php?t=66004
