Author Topic: RB25de wont pull on full throttle  (Read 1098 times)
GQDZLA
« on: July 27, 2012, 08:31:23 PM »
put your foot down gently and it pulls smoothly but has no real topend power, floor it and it just does nothing and actually slows down till you lift off, whats the first things to check? TPS, AFM? its not missing that I can hear or feel, just gutless as, any clues? did a few kms on the open road and runs 100kph smooth and not chugging fuel down or any other symtoms I'v noticed
« Last Edit: July 27, 2012, 08:33:12 PM by GQDZLA »
[SIGPIC][/SIGPIC]R33 GTR that got some serious upgrades and more to come!! 1998 Autech 260RS Stagea, 96 R33 GTS-4
« Reply #1 on: July 28, 2012, 01:21:02 AM »
Could be ECU pulling ignition timing and running richer due to knock, which makes engine feel very flat in midrange to close to topend.
If engine is knocking, check ECU for error codes, then check fuelpressure to rule out fuelpump failure (also check wiring to fuelpump), clogged fuelfilter and check sparkplugs (correct heatrange and gap). If they are ok, check for gasket leaks on exhaust, intake side.
TPS prevents engine going suddenly lean and hesitating before accelerating.
AFM might be a cause if dirty. Clean with CRC MAF cleaner.
