Author Topic: lowering r30  (Read 1281 times)
Evil13
lowering r30
« on: January 27, 2013, 09:32:22 PM »
i put lowering springs in the front but it is still to high and in the rear i used front r32 struts but its to soft in the rear the towbar hits the ground when i take off is their some harder springs i can use?
base
lowering r30
« Reply #1 on: January 27, 2013, 09:51:45 PM »
Cam get custom springs from Chamberlains in chch they make crobra springs any spring rate you want
AGRORB
lowering r30
« Reply #2 on: January 27, 2013, 10:02:53 PM »
Just be wary that the front chassis rails drop REAL low in these, I had all sorts of issues come warrant time, 40mm of clearance does that :D
Quote from: ibb&;559471
Quote from: nathan1017;591767
giving the knob to sdu.
project r30
lowering r30
« Reply #3 on: January 28, 2013, 07:49:53 AM »
i used r32 shocks with r33 springs and taller bump stops to fix the soft rear end. in the front ive used s13 knuckle with apexi n1 coilovers as lowering springs doesnt do much.
Evil13
lowering r30
« Reply #4 on: January 28, 2013, 06:36:52 PM »
Thanks ill keep a eye out for r33 springs.
