Author Topic: 4wd Rb25det Neo into S14 Facelift  (Read 2040 times)
Blk_Mumba
« on: April 27, 2013, 04:46:16 PM »
Installed a A31 engine sub Frame into the 14... Got the front shafts removed from the Neo and the holes welded shut... Was told I was good to go went to drop the motor in and the sump hits the sway bar... Was there something im forgetting? Anyone done this conversion before?
Any help will be appreciated.
gts-4r
« Reply #1 on: April 27, 2013, 05:17:07 PM »
get an a31 front sway bar that will fix it
jamind
« Reply #2 on: July 06, 2013, 04:19:17 AM »
Hi i have a A31 Cefiro SE4, 4WD, The front suspension is the same as an R32 GTR or GTS-4, The 4wd sub-frame sites further back to the standered Cefiro, Hope this info is not to late, Cheers Jamind
nismo_chch
« Reply #3 on: July 08, 2013, 11:02:18 AM »
Got a photo of how bad it is fouling? About to do a rb25det neo conversion on my partners S14. Going to modifiy the 4wd sump myself so may as well modify it to clear swaybar too as long as it isn't too bad.
gte
« Reply #4 on: September 15, 2013, 02:27:58 AM »
Any pictures of this you could post?
