Author Topic: My POS L20E  (Read 3356 times)
StageFumer11
My POS L20E
« Reply #15 on: May 13, 2013, 05:44:56 PM »
I was about to say, The afm might not be good. I was trying to see if it was a turbo one or not, which have a IAT sensor inside them. You can "run" and turbo one to find out, But the could tension might be different.
1985 R30 Skyline Coupe
AGRORB
My POS L20E
« Reply #16 on: May 13, 2013, 05:48:54 PM »
Can't find another AFM, new motor doesn't come with one either.
I'm gonna ****ing burn it :splat:
Quote from: ibb&;559471
Quote from: nathan1017;591767
giving the knob to sdu.
StageFumer11
My POS L20E
« Reply #17 on: May 13, 2013, 09:20:24 PM »
settle, this is the joys of a older vehicle, im sure i have a few afms around here somewhere
base
My POS L20E
« Reply #18 on: May 13, 2013, 10:05:16 PM »
Angry Scotsman  chill out man people  are trying 2 help u out
kyteler
    • http://blog.retro-classics.co.nz/
My POS L20E
« Reply #19 on: May 14, 2013, 12:35:01 PM »
Post the deets of your AFM on here, I'll see if I've got another one the same to send you to try.  You big fairy.
1963 Prince Skyline (S21)| 1973 Nissan Skyline (C110)| 1983 Nissan Skyline (R30)
My POS L20E
« Reply #20 on: May 14, 2013, 12:58:53 PM »
When AFM fails on a R32 it can make engine idle at around 1500rpm when cold or hot.
Forgot to mention, car has what looks like a VK or VL commy radiator wonderfully hori'd up with cable ties and flexi hose. Temp gets to about quarter, then drops cruising at 100 or going downhill.
But running rich, higher idle rpm could be due to the upgraded radiator keeping coolant temps too low (ECU stays on warmup tables). You are meant to retune ECU (warmup tables) to suit when coolant temps are lower with lower temp thermostat. But in this case radiator might be too big.
You would need to see what the voltage is from coolant temp sensor via multimeter to confirm the above.
Also idle rpm might be set too high as well, which adds to the problem.
Sometimes high idle can be caused by sticky or faulty IACV or choke on dash if it's a pre 80's Nissan.
StageFumer11
My POS L20E
« Reply #21 on: May 14, 2013, 05:27:52 PM »
Not a hotwire AFM on these, Older flap resistance.
Upgraded ratiators wont do to much with these. Thermostat will control those temps. He has a new Coolant temp sensor installed.
Auto choke on these ECU's Very basic system
AGRORB
My POS L20E
« Reply #22 on: May 18, 2013, 02:46:42 PM »
Final thought, wouldn't be anything to do with the TPS? Last thing I'm gonna try, then it's for sale, I can't afford to spend money on a daily, especially seeing as I've taken a pay cut of $4 an hour just to keep myself in a job.
StageFumer11
My POS L20E
« Reply #23 on: May 19, 2013, 07:21:36 PM »
Unplug it and find out, it will run fine without it,
Also, id remove "drum brake rear end" off your auction :)
