Author Topic: Flarkk I hate electrical. Audio wiring.  (Read 2965 times)
Ryeoon
« Reply #30 on: July 16, 2013, 10:12:56 PM »
It's lost charge with the amp just sitting there which I would figure means the remote wire is not wired properly but can't check until I get the battery charged again. I wired it up to the amp wire from head unit so not sure why this has happened.
« Reply #31 on: July 16, 2013, 10:15:45 PM »
Crap like this is so hard to diagnose over the net :(
Ryeoon
« Reply #32 on: July 16, 2013, 10:23:59 PM »
It's hard to diagnose in person with me!! Haha. If it's earthed properly and power supply to battery is sweet then it must be the remote wire I imagine. First thing I'll do is check voltage at amp connection on/off to see if the voltage is being cut off to it. If there is no voltage on remote wire while accessory is off then it should be all working properly correct?
« Reply #33 on: July 17, 2013, 09:28:31 AM »
Yep perhaps you didn't connect a remote wire but instead a constant 12V source. That's the only signal the amp gets to turn on.
