Author Topic: Callum's R32 :D  (Read 3610 times)
CNR3290
Callum's R32 :D
« on: June 11, 2013, 08:24:21 AM »
Hi guys here are some pictures let me know what you think,
« Last Edit: June 11, 2013, 08:27:22 AM by CNR3290 »
A31_25DET
Callum's R32 :D
« Reply #1 on: June 11, 2013, 09:48:14 AM »
Looks good man, those wheels will be fine to start with, just needs to be lowered a little,
once thats done bring on the manual conversion :D:D
Current Rides:
1996 R33 GTS25-T
1990 E39A VR4 EVO 0
CNR3290
Callum's R32 :D
« Reply #2 on: June 11, 2013, 10:29:20 AM »
Quote from: A31_25DET;616074
My thoughts exactly :D any recommended springs and shocks to use?
A31_25DET
Callum's R32 :D
« Reply #3 on: June 11, 2013, 11:26:18 AM »
would pay to ring around (im from chch originally so not sure who does what up here haha) but below are some of your options:
Factory shocks with upgraded springs - brands like King Springs, Dobi, do both a low and super low option from memory Low wll lower it about 20mm and the super low about 40-45mm
or you can have your shocks shortened and factory springs compressed,
maybe have a look on trademe see if anyone is selling any suspension with lowered springs already in them :)
for example here are some rears, wouldnt be any more than 30 buks i think to send it up, then you just need to find some fronts,
http://www.trademe.co.nz/motors/car-parts-accessories/nissan/suspension/auction-602092364.htm
« Last Edit: June 11, 2013, 11:39:07 AM by A31_25DET »
Current Rides:
1996 R33 GTS25-T
1990 E39A VR4 EVO 0
CNR3290
Callum's R32 :D
« Reply #4 on: June 11, 2013, 11:42:20 AM »
Okay sweet mate so i could just get super lows put on my currents factory shocks?
would that be the cheapest option or is it cheaper to buy some r32 shocks with super lows already on?
Hr31rb30
Callum's R32 :D
« Reply #5 on: June 11, 2013, 11:58:55 AM »
looks pretty tidy man minus that spoiler and a bit more lows and shell be mint hahaha well thats my opinion anyway
ARRRHHH THUUURRRTYYY ONNNEEEE
- Understeer is when you hit the wall with the front of the car
- Oversteer is when you hit the wall with the rear of the car
- Horsepower is how fast you hit the wall
- Torque is how far you take the wall with you.
Ryeoon
Callum's R32 :D
« Reply #6 on: June 11, 2013, 12:02:36 PM »
Quote from: Hr31rb30;616083
Agreed. No other way.
CNR3290
Callum's R32 :D
« Reply #7 on: June 11, 2013, 12:10:37 PM »
yeh cheers guy lowering is number one, trying to find some springs at the moment.
CNR3290
Callum's R32 :D
« Reply #8 on: June 11, 2013, 12:27:57 PM »
Just got told about 400 for super low dobys fitted, Sound okay?
A31_25DET
Callum's R32 :D
« Reply #9 on: June 11, 2013, 12:32:31 PM »
Quote from: CNR3290;616081
Yes you can, plus factor for this is you know that you are definitely getting "super lows" but con is that it may cost a little more
and pros for this Trademe option is that you will probably pick them up cheaper but the con is that you have no gauruntee that it is actually a "super low" may only be a "low" just depends on the sort of person you are buying them off,
Current Rides:
1996 R33 GTS25-T
1990 E39A VR4 EVO 0
A31_25DET
Callum's R32 :D
« Reply #10 on: June 11, 2013, 12:33:16 PM »
Quote from: CNR3290;616088
yea that sounds about right for brand new, who is selling/fitting?
in terms of the spoiler i really like these things aye, trying to find one to suit my cef. what are your guys thoughts?
http://www.trademe.co.nz/motors/car-parts-accessories/performance/body-kits-mouldings/auction-602165845.htm
« Last Edit: June 11, 2013, 12:36:46 PM by A31_25DET »
Current Rides:
1996 R33 GTS25-T
1990 E39A VR4 EVO 0
CNR3290
Callum's R32 :D
« Reply #11 on: June 11, 2013, 12:42:29 PM »
these guys are, should be able to get a better deal when i go in and commit to it too :D
http://www.autolign.co.nz/Manukau.asp
I dont mind those but tbh i prefer the look without a spoiler at all just looks smoother i think
A31_25DET
Callum's R32 :D
« Reply #12 on: June 11, 2013, 12:46:31 PM »
sweet have you tried Mag and Turbo? think they might be $385 ($15 you can spend on something else haha) cant remember if that was fitted or not though
Current Rides:
1996 R33 GTS25-T
1990 E39A VR4 EVO 0
CNR3290
Callum's R32 :D
« Reply #13 on: June 11, 2013, 12:54:35 PM »
na ill give them a call to and see what they can do for me :D
Callum's R32 :D
« Reply #14 on: June 11, 2013, 04:55:55 PM »
Factory shocks have usually had it after 30,000km. Probably due for replacement (As far as I know they are made by KYB, so can replace with KYB shocks that are fairly cheapish) that would improve handling, grip, etc.
Too low on factory shocks can make it hit the bump stop under top hat (top part of shock that bolts to chassis) and start to leak at top of shock body. Also they are not valved to suit lower springs, so don't work properly to control the expanding, contracting of spring. Worn shocks or incorrect shocks for springs can affect braking distance, acceleration, grip (could be worse than factory).
Main problems with factory setup is the bushes, shocks, joints, etc are worn out that causes excessive bodyroll. Those should be the first things to replace if car has done high km and haven't been replaced. It should drive like new once you have replaced those parts.
Best option would be to replace the shocks, bushes, joints if have play, etc.
