Author Topic: How to clean Air flow sensor - Easy as!  (Read 1956 times)
Tomy255
« on: July 23, 2013, 06:01:23 PM »
So replacing the panel filter in the Cefiro and decided to pick up some MAF cleaner, $20 from Super cheap but I've "heard" you can use carby cleaner don't take my word for it though! Anyway the can says it adds 4-10hp so it must be true lol but most our cars will have over 100,000kms so it doesn't hurt to clean once and a while.
Tools you'll need:
10mm socket - Bolts on airbox
8mm socket - Hose clamp
MAF sensor cleaner
Before I start just like to point out this will work on any car running a MAF usually EFI engines so not just RBs.
Step 1: Locate the bolts on the MAF connected to the airbox (Red arrows) use the 10mm to undo them
Step 2: Use the 8mm to loosen the hose clamps (blue arrows)
Step 3: Unplug the grey plug on the side of the unit then carefully pull the unit out of the hose my require some jiggling lol
Step 4: Once its out shake the cleaner and spray 10-15 times (short bursts) from a little distance onto the sensor behind the mesh. Don't over do it
Step 5: Lay the unit down then let it dry
Step 6: Put it all back together!
frost.motorsport
    • http://www.frostmotorsport.co.nz
« Reply #1 on: August 04, 2013, 07:34:19 PM »
CO Contact cleaner will also work.  The 4-10HP claim is a bit bold IMO... either way, don't use BrakeKleen!!
I wouldn\'t have road rage if morons didn\'t have drivers licences!
https://www.facebook.com/FrostMotorsport
Demco
« Reply #2 on: August 04, 2013, 10:30:59 PM »
but brakekleen comes in such a big can! how am i supposed to use it all ?? :laugh: i gotta get round to doing this so easy and probably very overlooked
♜♞♝♛[Firing order: 1-5-3-6-2-4]♚♝♞♜[/b]
ARRRHHH THUUURRRTYYY TWOOO
Progress 98%
[ ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||[/COLOR] || ]
base
« Reply #3 on: August 04, 2013, 11:05:57 PM »
It's that easy I've trained the missus to do it each oil change prob bit ott but she does it
Demco
« Reply #4 on: August 05, 2013, 12:35:59 AM »
Quote from: base;618788
haha i tried getting my mrs to service a car once... never again :splat:
she forgot about the oil sump plug and poured about 4 liters of new oil through the engine and right out the sump onto the floor got through about all 4 liters before she realized what was happening
Progress 98%
« Reply #5 on: August 05, 2013, 10:14:10 AM »
Good write up!
I noticed a difference in response after cleaning mine, it had a pretty thick coating of oil over the wire and inside it.
Tomy255
« Reply #6 on: August 06, 2013, 09:53:23 AM »
Cheers guys, haha yeah the "4-10hp" is a bit far fetched I think :P also forgot to add but I was doing this to see changes in fuel economy so I reset my ecu after application.
AGRORB
« Reply #7 on: August 17, 2013, 09:59:45 PM »
Good stuff that, certainly made a difference :)
Quote from: ibb&;559471
Quote from: nathan1017;591767
giving the knob to sdu.
