Author Topic: R33 S1 to S2 headlights wiring.  (Read 915 times)
MOSTDOUBTED
« on: July 29, 2013, 12:42:52 PM »
Been told there is some wiring that needs to be changed over, just wondering if anyone knows exactly what has to be changed when wiring the new ones up or is it straight swap over?
02 Holden Commdore SS VX
96 Nissan Skyline R33 GTS25 Sedan
Tomy255
« Reply #1 on: July 31, 2013, 10:21:47 AM »
I didn't read much of this but It may be of some help, a little old though lol
http://www.skylinesdownunder.com/forums/showthread.php?t=10850
« Reply #2 on: July 31, 2013, 03:19:27 PM »
Even if it does need a rewire, using a multimeter it will be an easy job to make everything work as it should :)
If you do use S2 headlights, you should also use a S2 bonnet. The top/inside corner is much sharper on the S2 headlights and the bonnet is shaped to match it.
