Author Topic: Boost gauge  (Read 2486 times)
R33Dan
Boost gauge
« Reply #15 on: August 28, 2013, 11:36:09 AM »
Quote from: mlracing.co.nz;619806
Yeah it means it hasn't got a signal from the sender, you haven't received yet?
I will follow up, super slow from Fastway.
Nope hasn't come yet pal.
R33Dan
Boost gauge
« Reply #16 on: August 28, 2013, 07:49:54 PM »
Just to let you know the cable came and everything works as it should :D
Need to take it out for a test drive tomorrow to see how accurate it is.
I suspect there's a kink in the vac line as there is waaaay to much of it that I had to hide away in the footwell somewhere haha.
Will cut it down toa good size if there is a kink and isn't giving a good reading.
« Last Edit: August 28, 2013, 07:52:17 PM by R33Dan »
