Hi Guys.
A bit of content to get through this time, with regards to lack of updates from previously attended events.
If you didn't know already, most of our updates are done via facebook & easy to keep up with.
So head along to
https://www.facebook.com/SlaterRacingNZ and give us a like in order to keep up to date.
Now unfortunately we missed out on posting multiple video's to this forum, but we'll make up for it in this post.
Our first test session was unfortunately not recorded, due to our go pro deciding to miraculously flatten it's self..
Hampton Downs Shakedown Session 10/01/15-----------------------------------------------------------------------------------------------------------------------
On our first un-recorded shakedown session we spent most of our time in the pits with teething issues, mainly surrounding wheel locking & massive under steer. And were unfortunately unable to resolve the issues we had on the day, so we opted to drive around them & slightly tweak the car to compensate.
So we returned back to hamptons again for the second time with all our issues still, some of which we took a good poke at fixing but others not so much. We opted for fresh rubber as our old semis had completely gone off, and also opted to install a fan shroud & new twin electric 12" fans to fix cooling issues. While the new rubber certainly did help a lot, the shroud and electric fans didn't do any where near as good of a job as they did.
Without further or due here is a link to Ethels second shake down:
https://www.youtube.com/watch?v=Ah_t4rNsqGgSo yet again we came away from the second shake down with a whole pile of issues.
With the oil cooler sitting right infront of the radiator blocking flow, it was causing our water temp to rise up to 110 degree's.
Moving the oil cooler to the right front corner fixed the heat soak, which meant we now had a stable 90 degree oil and water temp. With that one issue fixed it was now time to fully focus on why the car was locking up so easily, and why it was mostly the front left.
After spending hours researching online about my lockup issues, it finally clicked why I was having all these issues.
I'm sure if I posted about it, someone would have quickly told me that my factory bm38 bmc was causing bias issues. All simply because I upgraded to r33 gtst 2 pot rear calipers. So I opted to change my brake booster to an r32 gtr unit (not that I needed to), and also fitted up a brand new bm57 bmc. (Sorry no pictures)
Took it for a test drive after a bleed, and found that it still locked up the left front wheel.
The brakes felt amazing though and worked beautifully compared to before, previously I only had to slightly jump on them and they'd lock. After pulling the front calipers off & checked no pistons were seized, I found that there was no shims on the left caliper. Little shims go between the calipers mounting pegs, which slightly offset the caliper from the knuckle.
Because the left one was offset by a minute amount, it provided far greater clamping force than the right caliper.
So a couple of washers of equivalent size to the right caliper shims, were added to the left caliper which seemingly resolved the issue.
Here's a couple of pics from this shakedown:
Pukekohe Shakedown Session 06/02/15-----------------------------------------------------------------------------------------------------------------------
This session was so much better than all the previous ones.
We changed a few alignment settings on the front and rear, and also fitted up some whiteline sway bars.
For once the car was handing pretty well, with plenty of turn in but not nearly enough back end.
By the end of the day I was settling into a pretty good rhythm, turn one was a bit sketch due to a deep puddle right on the racing line. Which meant we couldn't take the corner at full pace
After punishing the car for a solid 13 laps, the brake fluid boiled which sent me into the pits on the last session a little early. Having the brake peddle completely hit the floor on me at the end of turn one was pretty fun
Here's some short clips of our blat around pukekohe:
https://www.youtube.com/watch?v=i2wVRl7zcqIAlso a couple of shots from the day:
S13 Hampton Downs Skid Pan 25-04-15-----------------------------------------------------------------------------------------------------------------------
This event was by far the most fun I've had driving in a long time.
With a completely flogged gearbox lever boot, we had gearbox oil spewing in the cockpit on our first run.
And our diff ratio was miles off for the lack of power we had, perhaps a 4.1/4.5 diff instead of a 3.9 would have skidded much easier. It took a bit of effort to fix the lever boot temporarily, once it was done we got right back into it.
The skid pan layout didn't change all day, which was a bit gutting to put it politely.
But it was still an immense amount of fun once people were game enough for tandems.
For this event we mucked around with the rear toe settings, and also fitted up a bunch of parts.
Replaced our lca's for 555 units, replaced our inner rack ends as one was bent slightly.
Removed the front subframe and moved the rack forward 25mm, so we could get rid of our gktech offset rack spacers.
Doing this meant we wouldn't struggle to replace a inner rack ends that had been fitted with loctite.
Here's a clip of some runs for the day:
https://www.youtube.com/watch?v=ZiwmAwIsId0Also a couple to many shots from the day:
At the moment we're tossing up weather we pull the car apart for the off season, and make a few well deserved changes.
For now we've started with something simple by replacing our d2 struts with some nice New BC Golds.
Out with the old:
In with the new:
