Author Topic: No Spark No Injector Pulse  (Read 1056 times)
NZ_SAVAGE-85
« on: October 04, 2014, 02:19:33 PM »
Hi guys first time posting for help.
I have a 91 r32 coupe running rb25det from r34 stagea.
Situation:
Was running sweet & lost power while driving, first thought id blown intercooler pipe off again as it had done bout 20 min earler ( was on way home to fix properly )
Idled down hill n pulled over, this is where it died, jumpd out went to push silicone joiner back on but found none off.
I have pulled cas, rotated sender, no injector pulse.
I have pulled spark plug n turned over with plug in coil, no spark.
I have 5.12v at two of four wires at cas plug with ignition on ) on other two.
I have power to injectors but none to coils.
I had a simular problem years ago and turned out to be the relay... changed that out but cannot rule that out stil as was a second hand relay.
Any help would be much appreciated.
Also i have a leak somewhere, i have to disconnect battery over weekend... tips on how to find leak also be appreciated.
fast4motion
Re: No Spark No Injector Pulse
« Reply #1 on: October 05, 2014, 10:31:49 AM »
With your key on, you should have constant 12V at injectors and coils. If there isn't voltage present at coils, it'll probably be a relay issue. You should feel the Ignition Relay click when the key is turned on/off. If it doesn't, check for voltage and ground at the relay connector terminals. Also, you can probably swap the Ign and ECCS relays for testing purposes.
