Author Topic: low mount to top mount conversion  (Read 6318 times)
cwu236
  • ECR33 RB25DET
Re: low mount to top mount conversion
« Reply #30 on: November 19, 2014, 10:08:18 PM »
I almost feel like u need a degree in this shit!
How much power u end up getting? Any probelms so far?
Thanks
Pandaemonaeon
« Reply #31 on: November 19, 2014, 10:11:19 PM »
We had to stop at around 5500RPM as boost was getting out of control at that point, and the engine was running a factory head gasket.
Soichi thought it would have made 300 at 0.8bar if it had been able to hold boost though.
pure methamphatamachine
cwu236
  • ECR33 RB25DET
« Reply #32 on: November 19, 2014, 10:21:17 PM »
Nice. Do it use sinco mani?
Thinking bout buying tomei head and arp studs. Might ask Soichi to check out how the other parts are doing at the same time
I try to ask Soichi these questions but every time I pop over he's by he's middle of a dyno sesh or sth!
Thanks
Pandaemonaeon
« Reply #33 on: November 19, 2014, 10:27:01 PM »
That was on a Sinco exhaust/ Greddy intake.
It had a 40mm wastegate at the time which caused the boost issues. I changed that to a 44mm but it still had a small amount of boost creep.
Once the bigger exhaust housing went on it was perfect at 0.8bar though.
« Last Edit: November 19, 2014, 10:30:05 PM by Pandaemonaeon »
cwu236
  • ECR33 RB25DET
« Reply #34 on: November 20, 2014, 10:22:56 AM »
Genuine greddy intake or a greddy style?
How much u pick that up for?
Thanks
Pandaemonaeon
« Reply #35 on: November 20, 2014, 11:43:07 AM »
Genuine. I got it with fuel rail/ injectors/ throttle body through a mate, so no idea on price.
I think you are looking at around $1500 for them at the moment though.
The 25 that is currently in my car has a knockoff one in it (came with it, I would never buy one), but it ended up costing about the same as a genuine one anyway as there were hours put into port matching to make it good enough, but even still, it's a poorly constructed piece of shit.
Once I have finished modifying my Greddy one and install it, I'll take some side by side pictures to give you an idea on the difference.
« Last Edit: November 20, 2014, 11:47:27 AM by Pandaemonaeon »
