Author Topic: electronic fuel controler  (Read 2267 times)
Mogiman
« on: March 15, 2015, 08:45:15 AM »
datasystem efc930 anyone used one ,have one,came with the new car and the manual is in Japanese
Thanks
Gaming Since you were a twinkle in your daddy\'s eye...
Re: electronic fuel controler
« Reply #1 on: March 15, 2015, 04:51:49 PM »
They will sell you an English manual lol
http://www.r-spec.com/manuals/out.html
Is it wired in and being used?
I don't like thinks like these More of a work around than a solution
Mogiman
« Reply #2 on: March 19, 2015, 01:14:18 AM »
Yes already wired and working ill look at that site,cheers ,I had a problem with that page contact doesnt work on it ,I have jap manual so might see if i can find a translator .
« Last Edit: March 19, 2015, 01:18:12 AM by Mogiman »
Pandaemonaeon
« Reply #3 on: March 19, 2015, 07:32:30 PM »
If it's anything like the VTEC controller of theirs I had even having a manual won't help unfortunately.
pure methamphatamachine
Mogiman
mapecu
« Reply #4 on: April 19, 2015, 12:41:20 PM »
anyone seen these before mapecu    .http://www.mapecu.com/faqs/
sk8seddon
« Reply #5 on: April 19, 2015, 06:12:37 PM »
i have a map ecu2, not great and tunner said it takes longer to set base tune / setup etc, so what you save in out right price you lose in set up/ wiring in.
might as well go link.
« Reply #6 on: April 19, 2015, 06:23:58 PM »
Its probably better to go with units that tuners are used to. Best value for money is Nistune chip although not many have tuned it in NZ, or Greddy E-Manage or HKS F-Con. These should all be under $1000 but Link will come to over $2000 plus tuning.
Mogiman
« Reply #7 on: April 19, 2015, 10:39:20 PM »
Greddy E-Manage Blue piggyback ECU $460 including inj and ign harnesses or should i go the ultimate one $1110 with plug in harness ,budget doesn't allow for link, I did have a look at the megasquirt too..$850-1100 with base tune loaded for the plus t, they seem to know their stuff .
« Reply #8 on: April 22, 2015, 06:51:42 PM »
From what I understand, piggy backs adjust signals from the ECU that go to engine. But if stock ECU decides to switch to knock maps during the tune, it can ruin the tune.
Nistune is good if tuner knows how to tune it properly.
