Author Topic: Bonnet Ungluing  (Read 1704 times)
Mogiman
Bonnet Ungluing
« on: April 06, 2015, 10:37:27 AM »
Hey guys and girls,
My metal bonnet is coming unglued from its bracing ,its mainly on the exhaust manifold side ,I'm picking the heat from it over time. I've had a good look and its def glued not tack welded ,as I've noticed just a little bit of flutter on it ,I've got the glue for it but i cant clamp the ones towards the center can only get the edge, has anyone had this problem and what did you do ?
Budget on this one doesn't allow for new bonnet unless someone has a real cheap one around then ill cut this one and vent it for track day use and may be able to glue it then,
Any help Cheers
« Last Edit: April 06, 2015, 10:40:22 AM by Mogiman »
Gaming Since you were a twinkle in your daddy\'s eye...
Re: Bonnet Ungluing
« Reply #1 on: April 06, 2015, 01:46:02 PM »
Hey guys and girls,
Any help Cheers
How much pressure do you need? Prop it with a length of wood and then pull the bonnet down on it and secure it with a bungee cord overnight or however long it takes the glue to cure.
Mogiman
Re: Bonnet Ungluing
« Reply #2 on: April 06, 2015, 11:27:32 PM »
I did think about that but it is like half the bonnet and would have to almost make a big jig with curves and all I may have to try anyway,anyone got any real powerful magnets i can borrow lol
[/quote]How much pressure do you need? Prop it with a length of wood and then pull the bonnet down on it and secure it with a bungee cord overnight or however long it takes the glue to cure.
[/quote]
Mogiman
Re: Bonnet Ungluing
« Reply #3 on: April 11, 2015, 04:03:39 PM »
done but it wasn't easy
Mogiman
Re: Bonnet Ungluing
« Reply #4 on: May 30, 2015, 09:11:18 AM »
Still not sitting right so brought a new one 65 bucks from mega car part good price and was in really good nick apart from a little paint fade but that wont matter as repaint coming up
Drift-monkey
Re: Bonnet Ungluing
« Reply #5 on: May 30, 2015, 01:16:44 PM »
I would have taken the bonnet off, laid it on the ground, glued it and stacked some shit on top of the glue to press it down..
