Author Topic: Fuel pump not priming?  (Read 942 times)
MOSTDOUBTED
« on: April 25, 2015, 03:39:57 PM »
Just put in my new rb25det S2 into my R33 and took out the original 25de S2.
Just wired as much as possible only one plug i'm trying to find off my alternator loom. But I just chucked the battery in and turned the ignition on to see if I had power and my fuel pumps not priming? I can fire the engine but obviously the pump not going its not going to fire up. Where is the fuel pump relay/fuse? My fuse box is in the front not the boot aswell.
Am I possibley missing a plug somewhere in my loom for it to turn on or the one plug from my alternator to the outside bottom fuse box plug thats causing my issue?
Any help would be great.
02 Holden Commdore SS VX
96 Nissan Skyline R33 GTS25 Sedan
Re: Fuel pump not priming?
« Reply #1 on: April 26, 2015, 06:05:31 PM »
Is the engine loom earthed at motor if not itll never work.
