Author Topic: S1 RS4 Auto Trans Service  (Read 1468 times)
Dumbledore
« on: October 30, 2015, 06:49:29 PM »
Hey everyone,
need to know how to do a service on a auto box in a s1 rs4.
need a full parts list and guide on what to do.
thanks in advance
Re: S1 RS4 Auto Trans Service
« Reply #1 on: October 31, 2015, 03:39:28 AM »
If you mean oil change you may not need any parts. You can buy a kit with a gasket and a filter but I found I could re-use the gasket and the filter is metal so you can just wash it with petrol or such like. You will need 12or so litres of atf - I just managed to find some Fuchs semi-synthetic in a 20 litre container.
The process is as follows:
If you want to do it yourself you need to dump the pan and clean it. Remove the filter, clean it and put it back. Refill through the dipstick. Then disconnect a line to the trans oil cooler and run it into  a 2Litre container. Run the engine till the container is full then put 2L down the dipstick tube and run the engine to pump out another 2L . Repeat until the fluid comes out clean and fill to the correct level.
Dumbledore
« Reply #2 on: October 31, 2015, 11:42:02 AM »
cheers man.
do i have to heat it up to running temp before dropping it? also do i need to run it through all the gears when im dumping the oil?
« Reply #3 on: October 31, 2015, 12:06:51 PM »
No and no although any oil flows more freely when it is warm.
Dumbledore
« Reply #4 on: October 31, 2015, 12:38:11 PM »
so i leave it in N or P ?
« Reply #5 on: November 01, 2015, 03:10:12 PM »
Do it in N but run up and down the range when you are finally topping it up.
Dumbledore
« Reply #6 on: November 03, 2015, 03:52:08 PM »
awesome Westy cheers
