Author Topic: r32 gts4 build  (Read 2074 times)
r32 gts4 build
« on: October 04, 2016, 02:56:38 PM »
Pretty standard rb30det build here I did for a friend anyway here are some pics.
Don't have pictures of everything so I'll just show what I have.
Here are a few shots of the clearance cuts that had to be done to the block to clear the bolts on the sump adaptor plate.
Crank collar..
Grub screwed crank
New rb26 oil pump which comes off later
Arp rod bolts that were used
Re: r32 gts4 build
« Reply #1 on: October 04, 2016, 03:36:35 PM »
Arp head studs
Fit in the block..
Cometic head gasket
Head acid dipped and had a little skim
Put onto the block..
New exhaust studs
Studs in the head.. pretty exciting to look at I know
Re: r32 gts4 build
« Reply #2 on: October 04, 2016, 09:00:05 PM »
Seeing as it now has a 25 head with vtc it needed some way to get to oil there so I this replacement plug up with a hole in it, if you've seen the internal method before this will make sense.
Now just some pics of the exhaust manifold and turbo box... I didn't have any input in choosing these parts by the way
Re: r32 gts4 build
« Reply #3 on: October 04, 2016, 09:10:10 PM »
In an earlier post I said the oil pump will need to come off again and now is the time, the reason for it is for an external (sort of) oil pick up because it's just easier with the 4wd sump.
So I welded a fitting on the oil pump for the external pick up
Blocked the original pick up gallery on the front of the block
Added this to the sump
original pick up modified
What it all looks like together
Looney_Head
Re: r32 gts4 build
« Reply #4 on: October 05, 2016, 07:44:22 AM »
nice build. interesting mod for the oil pickup. i am interested to see how you find that VCT oil feed mod, i couldn't find anyone that had success with it.
god is just an imaginery friend for grown ups
Re: r32 gts4 build
« Reply #5 on: October 05, 2016, 11:50:54 AM »
I have used the vtc mod before on another 30 where I just manually drilled the old plug and put it back in never had any issues.
Re: r32 gts4 build
« Reply #6 on: October 05, 2016, 02:50:10 PM »
China front facing plenum that was machined flat and painted black
800cc injectors
Got these from nissan so the injectors would fit properly and seal, they are just the same as the insulators on the 25 side feed rail
How it looks all together in the car
Coil cover I made up, I think it looks a lot better than the factory ones and it lets the heat escape.  Once it's painted and fit it looks nice.  If anyone wants one of these made or anything else laser cut that can be arranged
Looney_Head
Re: r32 gts4 build
« Reply #7 on: October 06, 2016, 08:17:53 AM »
looking good all together. that coil cover is good. is it going to be painted black like the rest?
Re: r32 gts4 build
« Reply #8 on: October 06, 2016, 12:24:25 PM »
Yeah I haven't got any recent pictures will probably get some this weekend, but yeah coil cover is the same color as the covers and it looks nice and stealth.  I will get some pictures with it on but it will be getting changed as I've decided to use some denso COPs.. pencil coils whatever you want to call them and they have built in ignitors so need need for the cut out at the back for the factory ignitor pack anymore.
Re: r32 gts4 build
« Reply #9 on: October 09, 2016, 11:55:27 AM »
Here is a pic with the coil cover on sorry for bad lighting.
Looney_Head
Re: r32 gts4 build
« Reply #10 on: October 10, 2016, 07:46:21 AM »
very nice. looks good.
