Author Topic: [ARCHIVE]: Door Panels  (Read 682 times)
« on: June 09, 2001, 09:27:50 PM »
boomtheroom
Unregistered User
(8/9/00 8:50:18 pm)
Reply  door panels
 anyone got any pictures on how to get to the front door
speakers on a 1990 gts 4 door ????
Phil
(8/9/00 9:45:54 pm)
Reply  Front Doors
 Open the door, there are two little caps there, flick them open using a flat head screw driver. Remove the two phillips screws.
On the very bottom of the door trim, there are two (or three) screws, remove these.
On the drivers side, lift out the window, and mirror control switches, unplug all these. On passenger side, use a flat head screw driver, and lift out a little plastic clip beneith the handle, there is 1 screw here. (Unplug window switch)
There are a few plastic clips, carefully pull the door off from around the edge. Lift it up, as you do it, so as to lift the top out from the frame.
This should be close enough to see you right.
Phil
